Sponsored by: Real Truck
1999 Guys HELP!!!
Old Aug 22, 2017 | 06:48 PM
f25099's Avatar
f25099
1999 Guys HELP!!!
Ok guys, i have a problem. i go out of town for work for a week and come back and my 1999 F250 V10 GAS, is acting up. It started when i tried to drive it and it didnt want to shift, it would rev up to 3000+ RPMs and finally shift really hard into gear along with the speed odo not keeping up and bouncing around not wanting to work. I also had my entire gauge cluster lit up with no key and door closed. all the lights were on and it was "dinging" like the door was open and it wasnt. you would hear it when you put your ear up to the door. so my first thought was to change the VSS (which i did) no help. so i started wiggling wire loops under the fuse box in the cab and the "dinging" quit.. i took it for a drive and it works like nothing ever happened. obv im guessing theres a short so i brought it to my mechanic and hes saying he couldnt find anything by the fuse box but he thinks its closer or even attached to the gauge cluster itself. could this be true? has anyone ever herd or something so crazy or had a glitch like this? why would the gauge cluster loop throw off the shift points?
Old Aug 22, 2017 | 09:00 PM
Wolfboro's Avatar
Wolfboro
How is your battery ?
A weak battery can cause wild/crazy symptoms .
Good luck,
Old Aug 23, 2017 | 06:18 AM
f25099's Avatar
f25099
replaced battery when i replaced the VSS. i was thinking the same thing.
Old Aug 23, 2017 | 03:34 PM
f25099's Avatar
f25099
Anyone?? Help wanted
Old Aug 24, 2017 | 07:00 AM
Bently_Coop's Avatar
Bently_Coop
Clean your grounds and get the alternator/battery load tested together.
Old Sep 12, 2017 | 01:10 AM
davidaz's Avatar
davidaz
speed sensor
bmxstreet15
Jun 1, 2009 01:04 PM
zuritabu
Oct 10, 2007 11:44 AM
Big Red F250 SD
Mar 31, 2006 10:11 AM
Beck
1983 - 2012 Ranger & B-Series
Dec 3, 2003 04:40 PM
taznpooh
Jun 25, 2003 06:31 PM
