Rust, and my Ranger
Old Aug 22, 2017 | 04:02 PM
johnday's Avatar
johnday
Rust, and my Ranger
Ya, imagine that, rust on an '04 Ranger.
Anyway, I'm easing myself into a bed floor complete replacement, and while under it today, I noticed the fueltank rear support strap bracket was no longer there. I've searched until I've run out of ideas, and haven't found a replacement bracket.
Anyone have an idea where I could get a bracket? The OEM one is riveted to the frame, not that big of a deal to remove what's left, but I need one to replace it.
HELP!!!!
Old Aug 25, 2017 | 09:11 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I have never seen the bracket anywhere as a replacement part. You might have to fabricate one yourself.
Old Aug 25, 2017 | 10:00 AM
johnday's Avatar
johnday
Ya, I may have to. As long as it doesn't look "too" redneck, some unistrut and allthread oughta work, both I have in the barn.
My dealer called me this morning and says he might have gotten what I need. They ordered it for me, and according to their catalog, it's called a gusset. We'll see.
Old Aug 25, 2017 | 02:20 PM
johnday's Avatar
johnday
Got my "gusset" as Ford calls it. The tag on the box said "Vintage Parts", LOL
Also some photos of the floor from topside.
Old Aug 26, 2017 | 09:15 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Looks like the bed floor was the victim of moisture trapped under a bed liner. If you weld in a new floor make sure to mark all four side of the inside walls so the new floor bolt holes line up nicely with the box to frame torx bolts.
Old Aug 26, 2017 | 09:46 AM
johnday's Avatar
johnday
Thanks for the tip.
The bed rotted from underneath, there was never a liner in there, and always covered by a tonneau.
I did have a bed mat, but as much as I looked, there was never any water between it and the bed.
Old Aug 31, 2017 | 11:16 AM
johnday's Avatar
johnday
Picked up a box down in the Duhtroit area the other day, best out of 5 I looked at. Front 2 crossmembers need rebuilding, the rest is just surface rust. After pressure washing, I'm going to use Corroseal to convert the rust, topcoat with Rustoleum, then a thick coat of rubberized undercoating.
Never used Corroseal before, so that'll be different.
Also broke loose all my bedbolts but one, luckily it wasn't the one over the gas tank.
Old Sep 3, 2017 | 08:56 AM
johnday's Avatar
johnday
Some headway. Cutout the bad spots on the crossmembers, power brushed, power washed, and hung up to dry.
Moved it into the barn for rust converter.
Welder took a dump on me, so I'm going to temporarily bolt stuff together until I get a new welder. Getting too late in the year to be screwing around with lots of other things to get done.
Old Sep 12, 2017 | 08:06 AM
johnday's Avatar
johnday
Got the rebuilt bed almost ready to be swapped. Removing my original bed likely today, clean up the frame, and have POR on the way. Gotta get this finished up, winter ain't far away.
Maybe some photos later today.
FORD LIFE
May 9, 2018 07:16 AM
chukar
Jul 23, 2016 12:33 AM
heymrdj
Feb 16, 2015 01:06 PM
tonyt22
May 8, 2014 08:43 AM
edwars2
Apr 2, 2007 06:53 AM
