Does anybody have pictures of a pretty decent stock condition room seam? Particularly near the pillar area. I was stripping back some paint and noticed that the seams were leaded in and was wondering if that was common, or even stock? Whoever did it seems (no pun intended) like they put another seam in the lead to make the line prominent. Of course, water got behind this and started the corrosion that I am "happy" to fix.
Thank you. Mine looked like it was stock; didn't seem like it had too much paint on it, and there was nothing under it. But that's not saying much if the person doing it did it right, but it peels off pretty easily...
I haven't noticed any lead used in the drip rails on either of my 1950 cabs. I don't know if this picture helps. The drip rails got bent up probably by someone lifting the cab with a strap and not protecting the rails with a block of wood.
