Radiator shroud
E5TZ-8146-G .. Fan Shroud / Marked: E5TA-RA or E5TA-8146-RA / 20 7/16" high x 28 7/16" wide / Obsolete
1985/91 F250/350 & 1988/91 F(Super Duty) 7.5L (460).
Diesels used a different radiator, fan shroud and radiator support.
The 1983/91 F250/350 diesel shroud is 25 7/32" high x 33 11/64" wide.
I see your problem.
The 1985/ 7.5L shroud (as NumberDummy posted) is E5TZ-8146-G superseded by E5TA-8146-RA. I couldn't find it listed in any of the aftermarket websites.
The mounting bolt spacing is 20-3/4", and the width is 28-7/16" with height of 20-7/16".
Looking at Gary Gragemahl listings, there are several shrouds with the same bolt hole mounting spacing, and close to the same W and H, but nothing exact.
I'm not sure how "exact" the H and W dimensions need to be.
If not exact, the shroud for the 5.8L is real close (same mounting dimensions. The shroud for the 5.0L and 5.8L is available everywhere.
The shroud width for the 5.8L is 27-15/32" and the width for the 7.5L is 28-7/16", so 5.8L shroud is 1" narrower).
Similarly, the 5.8L height dimension is 21-35/64" and the 7.5L height is listed as 20-7/16". So the 5.8L shroud is about an 1-1/2" taller.
No Ford dealer or obsolete parts vendor has any. There is one on ebay .. $74.99 .. seller (parkers_performance11) says it's NIB (new in box) and there's only one remaining.
Type the Ford part number into search...
1981 F100
15
11-15-2018 09:51 AM
Kelley11
05-22-2015 01:54 PM
dustyroad
08-09-2013 06:57 PM
