I just finished doing bellowed up-pipes, new KC stage 2 turbo and a new 4" exhaust, made the truck quiet, and no more leaky up-pipes, turbo is amazing. anyway I get everything finished last week and take her for a drive and when I turn right I get this vibration and hum. I took it to a parking lot and locked in hubs and threw her in 4 high to see what'd happen, yup she jerked like normal for 4 wheel drive on pavement, when i took it out of 4 high the hubs didn't release, had to unlock them to get her to stop acting like she is in 4 high. any thoughts as to what is causing the vibration and hum? wheel bearing? hubs going out? I can't seem to figure this out and it's driving me nuts.
I checked u-joints. Jacked truck up and everything was tight. Drive shaft seemed ok. Need to replace slip joint in it. It had some play. It only vibrates and makes the hum when I make a right turn.
I really believe the KC stage 2 turbo is your problem. You need a modified OEM turbo, which I just happen to have. I will do you a favor since you are an FTE friend, I will trade you straight up and even pay for shipping both ways...
Just kidding of course, the exhaust has to be just right when installed otherwise you will get what you are experiencing. I had a lot of trouble getting the downpipe set up properly, but since then it has been great.
Boy would I just love a modified OEM turbo. Lol. I'll think about it. Looks like I'm gonna mess with exhaust, see if I can get it figured out, then go from there. Thx for the suggestion.
I will 3rd the suggestion on the exhaust causing the issue. I had the same deal that I chased for a long time, finally found it was the exhaust rubbing.
And that is why I love this forum, I always get sound advice and from many sources. Always get plenty of guys confirming on a certain issue. You're all fantastic and thank you.
Here is my next question, what size injector can I get away with before I need to stud heads? I have 280k on the clock also. Need to be tow friendly up to 13k. I'm sick of my little brother and his dodge throwing a grappling hook out while he passes me on the hills and dragging me too. All while he laughs.
With new turbo and up-pipes, I'm hitting 28-30lbs @ WOT. I was thinking 180/80 from full force. Just trying to get some thoughts on it. I've got a donor in the garage, saving up so I can do it all at once.
Sous correct about most folks recommending studs above 40psi of boost. Of course, this is kind of a relative number and assumes CP's and boost are linear. A big charger will move more air at lower psi, so '40psi' could be too much.
That said, you should be fine with 160/80's and your turbo - without headstuds.
After installing a few sets of 238/80's now, I'm a believer in 'small' hybrids. This injector does everything the 160/80 does - only better. No need to make the ~500hp the 238/80 is capable of. If your hottest tune only makes 400hp, the 238/80's won't hurt your modded turbo and should not 'need' headstuds.
And until he he buys hard parts for that cumming(s), he will be trying to catch you on those long grades.
