Looking for experience/opinions
Old Aug 26, 2017 | 12:57 PM
  #46
riddleswest's Avatar
riddleswest
I understand that an F-250 would solve the issues easily. Just not in the budget right now so trying to be as safe as possible. I"m still under the GCVW by quite a bit. In my mind that means the truck is going to be able to stop safely. I get that I'm putting extra strain on the axles, axle bearings, and rear suspension but that's just where we have to be for right now.
Old Aug 26, 2017 | 01:19 PM
  #47
seventyseven250's Avatar
seventyseven250
riddleswest, I'm normally all over these threads, but have been away for a while. It looks like you are on the right track.
Formula for tongue weight with WD not attached is
(Drive plus steer axles with trailer) minus (drive plus steer without trailer).
The guys have given you some great advice, and overall, I think you are in a situation you can work with. Moving some weight around in the trailer to make the trailer axles take more load is an option. If you can carry your beer and ice chest inside maybe? Or run with fewer tools in the bed?
Old Aug 26, 2017 | 01:32 PM
  #48
RV_Tech's Avatar
RV_Tech
Just tossing this out for whatever, but if this kind of overload was posted on one of the truck camper forums, I think most folks would be asking why you are even concerned. Try what seventyseven250 is saying. Sometimes a little goes a long ways.
Oh, and don't race any more Toyotas (unless you win).
Steve
Old Aug 26, 2017 | 01:43 PM
  #49
riddleswest
Ahhh that's where the 940 comes from. Thank you. And like I said before the truck handles very well with the load. I'm probably going to buy the 15k rated reese hitch from my neighbor anyway. Its the straight line with the sway control and I think I can get the whole set up for about $300. The bars are rated at 1200 lbs. I don't think that's too much overkill.
Old Aug 26, 2017 | 03:06 PM
  #50
meborder's Avatar
meborder
Originally Posted by andym
I know you don't want to hear this... but you need a bigger truck or a smaller trailer.
Why?
He is under his GVWR and GCWR. Why is a bigger truck needed?
Originally Posted by riddleswest
So I took the rear axle weight with the trailer on and no WD hitch of 4660 lbs and I subtracted the rear axle weight with no trailer of 3380 and that's how I arrived at 1280. Is there another formula?
Yes.
You need to add the weights on the front and rear axles before and after and subtract the difference in the total between them.
The 1200 lbs you are seeing increase on the rear axle is because weight from the front axle shifts to the back with the trailer hooked job without a WDH.
Old Aug 26, 2017 | 03:10 PM
  #51
RV_Tech's Avatar
RV_Tech
Given that he is heavier on the front axle with the WD bars in place and not over his ratings, why should he care?
Steve
Old Aug 26, 2017 | 03:33 PM
  #52
meborder's Avatar
meborder
Steve
He is still unloading the front axle some. Though it is pretty good.
WD Hitch No WD Hitch
Front- 3020lbs Front- 2780lbs
Rear- 4340lbs Rear- 4660lbs
Trailer-6640lbs Trailer- 6540lbs
Total-14000lbs Total- 1380lbs (not sure why this changed 20lbs)
Loaded truck by itself- Front- 3120
Rear- 3380
Total- 6500
I'm not sure why people are saying he is overloaded. His GVWR is 7700 and his total weight is under that. I get him at 7360 all hooked up. Is he over on is RAWR?
I'm not sure there is anything to solve here except the rear sag. Put on some air bags, readjust the hitch for the new height and stick a fork in it - this one is done.
Old Aug 26, 2017 | 04:03 PM
  #53
RV_Tech's Avatar
RV_Tech
You are right about the weigh, my mistake (I guess I was doing the new math ). I agree with what you are saying. The 100 pounds difference on the front axle is putting a cooler of beer in the back seat. All I was ever pushing for was CAT scale weights.
I think I said earlier on in this thread, if the weights are good, all it is is preference.
Steve
Old Aug 26, 2017 | 05:10 PM
  #54
meborder's Avatar
meborder
Earlier in the post he said his RAWR was 4050, so he is over by a few hundred pounds there.
Would be nice to move that much to the trailer if possible.
But short of that, everything is much better than anticipated.
This is why you shouldn't scale your rig ... now you have a decision to make
I know what I would do.....
Old Aug 26, 2017 | 05:33 PM
  #55
RV_Tech's Avatar
RV_Tech
I am betting he can move things around, but I would also note, being a betting man, he is a long ways from breaking anything.
Steve
Old Aug 26, 2017 | 06:17 PM
  #56
meborder's Avatar
meborder
I agree 100% on both points.
As a side note, if you have the Reese WD hitch already, you can buy the straight line cams with absolute confidence. They do exactly what they say they do. Highly recommended.
The only downside is that you will have to relocate your brackets forward with the cams. Usually not a problem but I had to move my LP tanks to accommodate the new position of the snap up brackets.
Old Aug 26, 2017 | 11:48 PM
  #57
riddleswest
Uhoh....My current brackets are right behind my LP tanks now. Where did you move your tanks to? I was thinking if I had to maybe I could raise them up to clear the brackets.
Old Aug 27, 2017 | 07:13 AM
  #58
RV_Tech's Avatar
RV_Tech
Check out the Reese website to see if they do not already make an accessory to deal with that problem.
Steve
Old Aug 27, 2017 | 07:55 AM
  #59
meborder's Avatar
meborder
I just moved them forward a few inches.
Old Aug 28, 2017 | 10:38 AM
  #60
brandon_oma#692's Avatar
brandon_oma#692
scale most likely displays in 20lb increments and rounds to the nearest 20. you are measuring on 3 scales that round and adding them up. you will have some variance.
15+15+20=50
rounded 20+20+20=60
