Truck lean on driver side
Old Aug 22, 2017 | 05:47 PM
  #31
nascarjimmy's Avatar
nascarjimmy
I can tell you that my 14" & 15" never leaned and my 2017 sure doesn't.
Old Aug 22, 2017 | 07:29 PM
  #32
skanj0's Avatar
skanj0
Originally Posted by das_16
I know what your saying that's why I went with the OUO leveling kit to adjust the front end perfect level. It was 1/2 difference between driver to passager side in the front. Now it's leveled perfectly
Same here. Tired of shims stacked on top of the left coil.
Old Aug 22, 2017 | 07:32 PM
  #33
skanj0's Avatar
skanj0
A lot of people don't notice it, but it is very common. Tends to be easier to spot when the truck in parked on flat ground.
Old Aug 22, 2017 | 07:49 PM
  #34
das_16's Avatar
das_16
Yeah on my 12 and 15 i had the dealer shim it and my 17 i was like I am using the ouo kit to have it properly leveled. Because even with those shims it would be off. Ocd would kill me when I had the truck parked in the barn.
Old Aug 22, 2017 | 07:54 PM
  #35
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Ballast needed in the starboard rear!!
Old Aug 22, 2017 | 07:58 PM
  #36
cficare's Avatar
cficare
Originally Posted by Paw's 150 Lariat
Ballast needed starboard aft!!
There ... fixed it for ya'. Couldn't resist. I'm a shipbuilder.
Old Aug 22, 2017 | 08:10 PM
  #37
Paw's 150 Lariat
Thanks...one of my son in laws is a shipbuilder so he would have jumped me on that one also! Bow/Stern Fore/Aft right!
Old Aug 22, 2017 | 08:15 PM
  #38
cficare's Avatar
cficare
OK, sure ...but you ain't navigating any of my rigs ... on land or water!
Old Aug 22, 2017 | 08:25 PM
  #39
Paw's 150 Lariat
Son in law worked for Northrop Grumman building the San Antonio class stealth ships. He retired from Bollinger Shipyards designing the fast responce cutters...Bernard Webber class.
Old Aug 23, 2017 | 03:29 PM
  #40
cficare's Avatar
cficare
I'm familiar with both those classes of ships and yards. Ingalls is one of our "brother" yards under HII, and I'm at NNS ... aircraft carriers and submarines.
Old Aug 23, 2017 | 04:26 PM
  #41
LiquidSteam's Avatar
LiquidSteam
Are you sure about that? I thought everyone was crazy until I measured. My truck does not look like its leaning at all.... but the tape measure doesn't lie
Old Aug 23, 2017 | 04:42 PM
  #42
user 474747383's Avatar
user 474747383
I can measure mine in the drive way and then move it over 2" and measure again and get different measurements every time I move it. When I put the truck on the front end rack it measures 1/8" off side to side Front 45 1/8th Right and 45 on drivers side full of gas.
Old Aug 24, 2017 | 12:20 AM
  #43
willynilly's Avatar
willynilly
if the driveway was flat youll get the same measurement everytime
Old Aug 24, 2017 | 06:07 AM
  #44
user 474747383
There are no flat driveways in Va.
Old Aug 24, 2017 | 10:01 PM
  #45
mtnguy's Avatar
mtnguy
At least west of the tidewater area.
I wanted to get weights on my 5th wheel side to side, so of course the truck was on the scales also. My truck weighs 340 lbs heavier on the drivers side with about 3/4 tank of fuel. My truck sometimes looks like it is lower on the drivers side, and sometimes it doesn't. My F150 was like that also.
