o2 sensors
Old Sep 7, 2003 | 09:46 PM
traderguy111's Avatar
traderguy111
o2 sensors
I have a 94 explorer with about 100,000 miles on it. It doesnt have much power and it pings really bad going up hills. I was wondering if the o2 sensors are going bad, they have never been changed. How do I know if they are bad? How long should they last? Does anybody have any other suggestions?? thanks Dan
Old Sep 8, 2003 | 12:40 AM
f100guy's Avatar
f100guy
o2 sensors
i have no idea, sorry
Old Sep 8, 2003 | 07:04 AM
1999XLT's Avatar
1999XLT
o2 sensors
Bring it to an Autozone if you have one near you. They scan it for free and tell you the trouble
Old Sep 8, 2003 | 08:50 PM
Duderoy's Avatar
Duderoy
o2 sensors
Look in your manual, I think Ford recommends every 50K miles.
Old Sep 10, 2003 | 11:28 AM
Ecuri's Avatar
Ecuri
o2 sensors
The O2 sensor is kinda like a little battery. Ground is the case and the single lead is the + terminal. It "turns on" at about 600 degrees F and will produce from between 0 to about 1VDC depending on the oxygen content of the exhaust. .7 volts is right on. lower is rich, higher is lean. it is not linear. Slope is very high at .7 and trends off on either side. A DVM will tell you if they are working. They can be "cleaned" with a propane torch... the idea is to burn of the carbon build-up and not melt the sensor. But at 35$ each, I just buy new ones.
This is assuming you have one wire O2, there are heated versions that operate at low EGT. GL
Old Sep 10, 2003 | 10:53 PM
roly1's Avatar
roly1
o2 sensors
check your egr valve
Old Sep 11, 2003 | 10:50 PM
circledirt's Avatar
circledirt
o2 sensors
MAF sensor gets covered with trash over time and the result is a lean running engine. Too lean means no power . Remove two torx screws end clean wires of MAF with spray brake cleaner. If O2,s were goin bad check engine lite should come on.
GITanker
Feb 24, 2013 09:35 PM
charlie00tj
Bronco II
Jul 16, 2010 05:22 PM
Webslinger
Oct 3, 2005 01:03 PM
rgreen01
Jan 3, 2005 12:25 PM
Jrock909
Nov 16, 2004 07:33 AM
