Brake line installation
Old Aug 18, 2017 | 09:29 AM
GoldCo's Avatar
GoldCo
I'm looking for tips or "best practices" for running brake lines. Got Speedway firewall booster/MC, proportioning valve, and residual valve (drum/disc).
Just picked up 25' roll of 3/16" line. Mostly concerned about going from cab (MC) down to frame. Do you install a joint/connection or just a 90* bend at frame… and then remove lines from MC should cab ever need to be pulled? Also seen "circles" at MC before dropping down to allow for flex. Necessary?
Advice and photos appreciated. Thanks!
Old Aug 18, 2017 | 01:07 PM
Mixer man's Avatar
Mixer man
The "circles" aren't just for cool looks. They are vibration frequency attenuators.
Old Aug 18, 2017 | 03:48 PM
GoldCo's Avatar
GoldCo
Smile
yep, just wondering if there are other means for same end, since you don't see them on all setups... (i'm not sure i'll be able to replicate 360˚ turns with a DIY bender??).
Old Aug 18, 2017 | 04:14 PM
Mixer man's Avatar
Mixer man
I wrap the line around a spray can and then fit.
Old Aug 18, 2017 | 06:20 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
The best tip I can think of for bending up your own brake lines is this;
Check, and then double check, and then check a few more times that you have slipped the fitting nut on the line before making the flare.
On a related note, double check that the fitting nut is on the last run before the flare and not stuck behind a bend.
I have seen several home made tubing straighteners the people have fabbed up for straightening the brake line after unrolling it. The straighteners were nothing more than a some angle iron with several sliding glass door rollers mounted to it so you could feed the tubing through the rollers to straighten it out.
Also, secure the brake lines to the frame every so often to reduce rattling
Good luck
Bobby
Old Aug 18, 2017 | 06:23 PM
jniolon's Avatar
jniolon
old and in the way
don't know if this will help but it might
https://www.fordtruckzone.com/thread...trucks.661906/
john
Old Aug 18, 2017 | 06:41 PM
Mixer man's Avatar
Mixer man
I just stand the tubing coil on edge, put a weight on the loose end, and just unroll it across the floor. What could be easier?
Old Aug 19, 2017 | 09:13 AM
Jules The Great's Avatar
Jules The Great
For mounting brake lines I just bought these clamps. With 3/16 line and a piece of 5/16 vinyl tubing they should hold them perfectly.
Amazon Amazon
Old Aug 19, 2017 | 10:11 AM
The Outlaw's Avatar
The Outlaw
I have a frame mounted master and I used stainless braided lines to connect to the hard lines. I also first bought a role of brake line and could NOT get the lines as straight as I wanted them. Really was not a whole lot more to get straight lines vs getting role.
Old Aug 19, 2017 | 12:43 PM
petemcl's Avatar
petemcl
Also allows adjustment for differences in length between what you measured and what is real.
Old Aug 22, 2017 | 02:57 PM
GoldCo's Avatar
GoldCo
pete, was that a "kit" for the heat/noise dampening material in the cab in that photo in your sig, or did you piece it all together from a roll?
thanks.
Old Aug 22, 2017 | 03:16 PM
petemcl's Avatar
petemcl
thanks.
This is XMat from Eastwood and it comes in sheets. You need the roller and sealing tape to do the job right but it is fairly easy to install and I liked the results.
Old Aug 22, 2017 | 04:06 PM
GoldCo's Avatar
GoldCo
P.S.
Does the hard line running to rear axle go underneath driver framerail?
Old Aug 22, 2017 | 04:19 PM
Jules The Great
Mine ran inside the driver rail at the bottom and was retained by little metal clips. I am not sure on originality.
Old Aug 22, 2017 | 04:26 PM
petemcl's Avatar
petemcl
Inside the rail. There should be clips that hold it near the bottom. There are holes in the crossmembers to allow brake lines through. There is a bracket back by the axle that holds the connection of a flexible rubber line to a hard metal line.
