In "real life" the 450 is not a heavier platform. It shares the same exact frame as all the trucks do, even a lowly F-250 SRW Crew Cab long bed has the identical frame as a 450. And the 350 DRW and 450 share the same exact springs and spring rates. Bigger brakes and a heavier duty version of the same axle, along with the higher rated tires are all that separate it. But given that the axle tube size is identical, and these are full-float axles with all the "weight" being borne by the tube, there should be no difference in axle capacity.
If you have a camper in the truck bed weighing 4500-5000lbs, you have already used all, or even exceeded, the max payload capacity of the 450. That leaves you zero ability to tow a trailer at the same time...especially if you are planning a long hitch extension which is what most of the truck campers require...that further lowers tongue weight.
By platform I meant brakes, axles, wheels and tires. Frame is the same as is the engine and trans. But the wide track front end sure isn't.
I'm aware nearly all one tons are over loaded when carrying a big slide in. I'd just rather have the 110psi tires underneath it. I've seen guys using F350's for the same task that I want to. These trucks are stout.
On the non mech side of things.....I like the look of the 19.5's and that big front axle.
Just remember that the springs are the same too. I'd say that will be the first limiting factor.
Yep, same spring rates as far as I know.
I'll be using air bags anyways for the camper to keep it level.
I'm months away from driving it and I'm already thinking about what I'd like to add to it.
Now I get to start looking for a camper. I won't be purchasing this until next summer at the earliest. I have read great things about Arctic Fox.
It was an easy decision in 2015 for me to go with a 2016 F450. In 2017, it was a really really hard decision. My main and only regret is the turning radius, which I am working on improving!
I just left a friend shop who specializes in extreme suspension work. He looked at my front suspension, and given my tire size, feels he could easily and safely grind back the stops to allow for a 44 degree turning radius without any fear of binding the U-joints or components making contact.
Soooooo.. might be something happening soon.... a little more measuring before I jump into it.
Awesome. Let us know how it works. Shouldn't be an issue since the 1550 joints come standard now.
I wonder if an axle from a wrecked 2015-16 F350 wide track would work?
If you're going to do an entire axle swap setting up gears is nothing. The carrier and housing should be the same between the two if you run 4.10s.
I would think 4.10 and 4.30 should share the same break. Might just be a matter of swapping carriers and pinions.
Speaking of gears, the 4.30 sets in the 450 I ordered today are limited slip. I know this axle is new and I am wondering if anyone has installed an air locker yet? I know that an ARB needs an open carrier.
I have had good and bad experiences with limited slips. My FJ40 runs ARB's in both ends. Is the limited slip from the factory ok for sand and loose dirt ect.
This truck will be going to the badlands for mule deer and to the farm for moose.
One more thing I would like to add.
Although I will never twist a shaft on this rear axle I consider the ultimate strength of an axle being measured by its spline count. As a mechanic, and a guy who builds trucks for crawling, I have replaced many shafts. Full floaters and c clips. Of course if you are dealing with spindly GM 10 bolt tubes and the like this would not apply.
The tube strength is something that most builders would regard as secondary to spline count in a heavy duty axle. When an an axle lets go its at the inner end, then you get out the long magnets.
What do you mean the ARB needs an open carrier? The carrier is completely replaced with the ARB. only parts that are reused are gears and bearings.
The other issue is ARB doesn't make a locker for the DANA M300.
