Power steering O rings
Old Aug 17, 2017 | 08:40 PM
JTB321's Avatar
JTB321
Anyone have a part number or suggestions on where to get the O rings for the power steering high pressure lines on the rack? I believe the rack is a 1988 Thunderbird.
Old Aug 18, 2017 | 04:30 AM
KULTULZ's Avatar
KULTULZ
Dealer would be my first stop. NAPA should have them.
Old Aug 19, 2017 | 04:51 PM
CBeav's Avatar
CBeav
One of those cheap o-ring kits at Harbor Freight should have what you need. I use them, they work fine.
Old Aug 19, 2017 | 06:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E1BZ-3591-A .. Teflon O-Ring-Use with SPR-AE Ford gear / Replaced? Obsolete?
1981/83 Fairmont/Zephyr; 1981/86 Capri; 1981/89 Mustang/Cougar/Thunderbird; 1982/87 Continental Sedan; 1983/86 LTD/Marquis (Fox body midsized); 1984/89 Mark VII.
This part number does not come up on Ford's online parts catalog website and the online parts catalog doesn't show the O-rings. The number probably has been replaced, or it might be obsolete.
Whiz down to the auto parts store, buy the O-rings for one a these applications. Some of the 1981 cars came with a TRW gear that uses different O-rings.
Old Aug 19, 2017 | 08:33 PM
JTB321's Avatar
JTB321
Thanks all appreciate your input. I guess the only issue with the HF O rings is they need to be oil resistant? I'll check what material they are made of.
Old Aug 20, 2017 | 05:10 PM
CBeav's Avatar
CBeav
If the o-rings you have are white, they're teflon and square cut. If they're black they're neoprene. The HF ones I've been using have worked fine for hydraulics.
Old Aug 20, 2017 | 09:21 PM
JTB321's Avatar
JTB321
Thanks Beav, they are the black ones. I'll call by HF and check out their stock.
jfb50
Aug 11, 2017 03:52 PM
Jesser02EX
May 5, 2015 09:15 PM
gearhed1971
Aug 25, 2006 03:52 PM
tonpartain
Mar 17, 2006 11:54 AM
mobleyt
Feb 8, 2003 08:26 AM
