04 6.0 F250 no throttle response
guys I need a little help trying to figure out what is up with my diesel. first off i swapped the motor and trans in it with a motor and trans out of an 05 everything bolted and plugged in perfect. Once i put it all back together crank up and ran fine. so put in drive and made it about 200 yards and the truck, lost all throttle response so i killed it and tried to crank it and it would turn over, just wouldn't fire off. so got it back and finally got it to crank back but when I mashed the throttle, nothing and also the oil pressure gauge dropped and will only idle for about 3 to 4 mins before slowly dyeing. replaced the high pressure oil pump, and still same thing the only the code is the number 2 glow plug...
EricdeToad
02-24-2015 09:27 PM
JBSIXGUNS
03-20-2012 06:10 PM
