Stock tire ?
Old Aug 17, 2017 | 08:19 AM
Steelhant's Avatar
Steelhant
Stock tire ?
Hi, my 2017 F-250 Lariat came with Michelin tires, under the truck the other day, noticed the spare is a Firestone....is that normal, seems odd ?
Thanks,
Chuck
Old Aug 17, 2017 | 08:22 AM
crewzer's Avatar
crewzer
Question
What size and style tires?
Regards,
Jim / crewzer
Old Aug 17, 2017 | 08:24 AM
Steelhant's Avatar
Steelhant
The 20" that come with the truck, spare same size.
Old Aug 17, 2017 | 08:25 AM
crewzer's Avatar
crewzer
Exclamation
You may want to double-check the spare... It may well be a slightly smaller LT275/70R18E A/T tire on an 18" wheel.
HTH,
Jim / crewzer
Old Aug 17, 2017 | 08:34 AM
BowtieConvert's Avatar
BowtieConvert
Same here. 20" Michelins with an 18" spare. Mine is a Goodyear Wrangler. Limited space under there.
RJC2's Avatar
RJC2
My King Ranch has the 20" wheels and a 18" Firestone spare. The circumference of the tire is the same on both. Ford doesn't put high dollar wheels under the trucks for spares.
At least Ford isn't putting a can of fix-a-flat (no spare) under there like Hyundai does.
Old Aug 17, 2017 | 08:40 AM
MEBE's Avatar
MEBE
20 inch Michelins with an 18 inch Goodyear Wrangler for a spare. Spare is a good looking tire, I wish the Michelins were
Old Aug 17, 2017 | 09:03 AM
Steelhant's Avatar
Steelhant
Thanks for the responses. never looked at the size, thought they be the same.
Old Aug 17, 2017 | 10:13 AM
seventyseven250's Avatar
seventyseven250
For smaller vehicles, the "no-spare" option actually makes a lot of sense. Most drivers aren't gong to change a tire anyway, they'd just call roadside assistance, so a smaller a lighter emergency solution is pretty smart.
I work at a car rental company and about the only time a spare tire gets used is when it's stolen right out of the vehicle!
I'm happy to have a "real" spare on a pickup however, as with me, I'm more likely to be out of cellular coverage or towing/hauling where a full size spare is a safety issue.
Old Aug 17, 2017 | 11:08 AM
CRSFX4's Avatar
CRSFX4
Ford does just like "Hyundai does" with the Mustang....no spare, but they do include a POS air compressor....that has a "Replacement Date" on it......no kidding.
Old Jun 16, 2021 | 02:00 PM
Gonefhsn's Avatar
Gonefhsn
Appreciate all the input in this thread. Changed my circumference to 2770, Did a relearn on PCM and TCM, no CEL and speedo is with in 1 MPH of GPS at 70+. 2020 F250 Platinum with 6" Fabtech lift rollin 37x13.50x22 Nitto Grapplers
You all rock thank you
Old Sep 3, 2024 | 06:31 PM
WXboy's Avatar
WXboy
My Mustang GT with the 5.0 Coyote has a spare tire, jack, and tire wrench in the trunk. And it wasn't an optional add-on.
As far as steel 18" wheels under the trucks for spares, they do that because most people never remove them for cleaning or to use them and so they get blasted by weather, road grime, salt spray, etc. constantly. Steel holds up better, is less expensive for them, and can be sanded and painted if need be by the owner later down the road.
BigJC
Apr 19, 2019 05:10 AM
ATX SD
2015 - 2020 F150
27
Jun 3, 2018 04:17 PM
Matt Geller
Mar 31, 2018 08:48 PM
DieselMama
Nov 22, 2017 11:04 AM
montauk1
May 31, 2016 09:47 AM
