Reverse lights stuck on
Old Aug 16, 2017 | 08:00 PM
163junk's Avatar
163junk
I am working on an 08 E350 6.0 which has the reverse lights on with the key on all the time. First time I've seen that. I'm looking for a wiring diagram for an 08, I skip from 03 to 09 in my diagrams. Looks like Ford went to a larger under hood fuse box in 09, so nothing I have is close. With the trans and pcm unplugged, I still have a signal to the reverse light relay.
Old Aug 18, 2017 | 06:36 PM
163junk's Avatar
163junk
Found it
Got a diagram from a buddy. Ended up being a bad relay in the aux1 relay box which was unclipped and laying behind the underhood fuse box. Relay was stuck on, had a little green cheese around the coil side.
bigric
Aug 24, 2018 10:10 AM
Faceplant409
Mar 15, 2018 07:23 PM
Nubs15
Feb 16, 2018 10:23 AM
icr_03
Jul 13, 2017 01:18 PM
skoveng
Electrical Systems/Wiring
Feb 24, 2009 07:07 PM
