Parking garage
Old Aug 16, 2017 | 12:28 PM
Hunt'nDawg's Avatar
Hunt'nDawg
Parking garage
I'm looking to add a 2" leveling kit and 325/60/20 BFG's to my 17 F250 King Ranch, but have some concerns on the overall height clearance. My truck sits at 6' 6" today (81.5"). I believe the overall new height with lift and tires will put me at 6' 9". My parking garage clearance at my office (I know, it sucks living in the city) is 6' 9". I know it is going to be a tight fit but looking for some help. Thanks.
Old Aug 16, 2017 | 12:41 PM
duckduke's Avatar
duckduke
Get one of these and pray!!!
Amazon Amazon
I am not much help........ but I will let you know there are a few threads on this already. Try search for "parking" or "garage" etc.
Hope this helps!!
Old Aug 16, 2017 | 12:45 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
You lost me at the 6'6" part which I figure at 78 inches tall. Adding a leveling kit and the extra height of the tires which show 35.4 inches tall I think you may be close to rubbing at the 6'-9" height of the garage. Why take a chance?
Old Aug 16, 2017 | 01:01 PM
cficare's Avatar
cficare
Carry a compressor and let the air out of your tires until you exit the garage. Actually, I also park in a garage, but I'm going to maintain stock height. My problem is our garage is posted as 7'2" clearance, but that excludes the speed bumps ... and I'm certain the antenna will hit the overhead. I wonder it that "Stubby" works well for reception.
Old Aug 16, 2017 | 01:06 PM
Hunt'nDawg's Avatar
Hunt'nDawg
I have a stubby antenna already and have noticed no change in the reception on regular radio or XM.
Old Aug 16, 2017 | 01:10 PM
Hunt'nDawg's Avatar
Hunt'nDawg
You are correct, 78" is 6'6". I love the look of the truck with the leveling kit and tires. But the risk of rubbing the roof just isn't worth it.
Old Aug 16, 2017 | 01:54 PM
xxxsherpa's Avatar
xxxsherpa
Exchange the rear block to level the rig and don't worry about garage fit.
Old Aug 16, 2017 | 02:22 PM
cficare's Avatar
cficare
Best solution I've heard, and it may be one I'll consider.
Old Aug 16, 2017 | 02:30 PM
2017FSD's Avatar
2017FSD
Just remember the tallest spot on your truck is back off roof on top just before 3rd brake light.
Old Aug 16, 2017 | 04:14 PM
jaherbst's Avatar
jaherbst
At 6'9" and 6'9" you will need a lot of speed to make it to your parking spot. It's called a speed wedgy!
Why would you even consider this just to look like "Billy big Truck" Sit down and rethink this.
Jack
Old Aug 17, 2017 | 12:14 AM
FlyinAg's Avatar
FlyinAg
Dude, you are going to trust that the 6'9" height disclosure on the garage is correct? I am sure the tolerances are not great... last thing you want is for the 6'8" pipe junction hanging down to split your truck's wig! Trust but verify!
Old Aug 17, 2017 | 07:52 AM
triniexr's Avatar
triniexr
Right before I get my truck I'm going to go to my parking garage with a measuring tape and measure the lowest points. It says 6' 10" but the signs look pretty low.
Old Aug 17, 2017 | 07:55 AM
KCJackson1's Avatar
KCJackson1
At 81.5", your F250 4x4 is already at 6'-9.5" - you're just making the cut of that 6'-9" garage as it is... the garage figure is likely a "maximum vehicle height" value, as opposed to an absolute minimum clearance. Adding the level kit and the big donuts will put you at about 7 feet even. If that garage is your only option to park at work, don't make the mods - or you'd have to find an open-air lot somewhere nearby.
Old Aug 17, 2017 | 08:17 AM
Wes Hightower's Avatar
Wes Hightower
Get a stubby just because they look great over some lame oem antenna. I had someone break my antenna off in a parking lot just for the hell of it years ago and they scratched the paint real bad which required a repaint. Well worth the price of a stubby.
I was considering putting 37's on mine with a minor lift but my truck barely sits under my a-frame canopy. I'm not trading lift for exposing it to the elements.
dmanshane
16
Aug 12, 2012 05:56 PM
SlickYamaha
Nov 20, 2011 08:37 PM
moosesp
2009 - 2014 F150
Apr 29, 2009 01:47 AM
Boo_Daddy
Feb 6, 2009 10:43 PM
nick21
2004 - 2008 F150
Oct 20, 2004 02:35 PM
