Tires
Old Aug 12, 2012 | 12:41 PM
dmanshane's Avatar
dmanshane
Tires
Is anyone running 305/70r16 on their stock height 4x4 ????? any rubbing issues ?
Old Aug 12, 2012 | 01:48 PM
pin8246's Avatar
pin8246
I dont know the answere, but just getting done with the leveling kit on mine, I would say they would rub. Thats basically a 33x12 tire. Most 2 inch leveling kits show that they clear 33x12.5 with it on, so without it I dont know.
Second in my opionion is it it was a brand new suspension you may be able to clear them, but after 10 years of so of wear on them you start getting the sag in the front. Basically your leafs and not as arched anymore. The 2.5 leveling kit I just put on is just that, 2.5 inches. But due to the tired suspension that was on it and the arch not being as noticable anymore, that 2.5 inches was actually about 4 inches because it corrected the sag from wear and tear on it.
So to me, I dont think you could clear them just by using my logic, but then again I could be wrong.
Old Aug 12, 2012 | 01:52 PM
dmanshane's Avatar
dmanshane
See I can't to a lift or leveling because the way it is I can't go any higher with new tires I have bout a quarter inch of clearance in my garage door
Old Aug 12, 2012 | 01:55 PM
pin8246's Avatar
pin8246
Yea thats about all I had. When I did it I had to switch my trucks around. Now my 2wd Dodge Cummins is in the garage, and the F250 is out in my shop.
Old Aug 12, 2012 | 01:59 PM
pin8246's Avatar
pin8246
and compared to stock the new tires would be 1.2 inches taller than stock. so that would lift your truck about half an inch. If you only have a quarter to spare, even if this size fits, it may not fit in the garage.
Old Aug 12, 2012 | 02:09 PM
dmanshane's Avatar
dmanshane
Oh I forgot to mention I'm
Running 285 75 16 which is a 32.76 11.42 and the 305/70r16 is a 32.68x12.40
Old Aug 12, 2012 | 02:13 PM
pin8246's Avatar
pin8246
The width is what your going to need to worry about I believe. Are you on stock wheels? Im running 35x12.5 on the stock wheels, and even though I have a leveling kit, and bigger blocks in the rear, at full turn my wheel rubs the front leaf springs.
Old Aug 12, 2012 | 03:49 PM
dmanshane's Avatar
dmanshane
Yes stock wheels
Old Aug 12, 2012 | 04:57 PM
pin8246's Avatar
pin8246
That wide your going to be close on rubbing I would think. Your not going up much in height so that should clear. Only thing I can think is have someone get in it, turn it to full lock and measure the distance from the front of the tire and rear of the tire on each side. Your going up about an inch in width, so if you have more than 1/2 inch difference between the leaf and either side of the wheel, you should be fine.
Old Aug 12, 2012 | 05:03 PM
dmanshane's Avatar
dmanshane
Ya I need to measure it the tires I have on front now are bout 95 percent and rears are bout 75
Old Aug 12, 2012 | 05:13 PM
pin8246's Avatar
pin8246
Sorry got in middle of talking about work and didnt finish what I meant. Measure from the front and rear at full lock to the leaf springs. Didnt put the leaf part in there.
Old Aug 12, 2012 | 05:20 PM
dmanshane's Avatar
dmanshane
I'm not impressed with hankook mt they two soft it gets sketchy pullin a gooseneck
Old Aug 12, 2012 | 05:25 PM
dmanshane's Avatar
dmanshane
I understood what you ment
Old Aug 12, 2012 | 05:27 PM
pin8246's Avatar
pin8246
I like my Dick Cepek tires, but im also in TX and dont deal with any snow, and I dont tow as much as im guessing you do.
I would have to look at my Dodge to remember which tires im running, but im running the same thing it came with from the factory because they worked for towing, 10ply, and lasted a long time. They are about 350 a piece for stock tire size, so a little expensive, but not agressive enough for the Ford.
Old Aug 12, 2012 | 05:43 PM
dmanshane's Avatar
dmanshane
We don't get much snow here in western Kansas I just like the aggressive tread for tornado chasing in the spring in the mud but I think I will be buying nitto teragrapplers next I heard they do fair in mud and snow ... We normally get one big snow a year 8-15 inches then all the other snows are a couple inches
