Max towing capacity
Old Aug 16, 2017 | 10:57 AM
Jesse73iditurbo's Avatar
Jesse73iditurbo
Max towing capacity
1993 f350 7.3 turbo diesel. Single cab 8 ft bed srw. 4:10 gears stock suspension with a 5spd. Max towing capability. I'm only curious. I read mixed things so I have no clue what's accurate. What is the max trailer weight capacity? And what is the max load to have as for weight on the rear axle and tongue weight?
Old Aug 16, 2017 | 11:37 AM
mrollings53's Avatar
mrollings53
Do you still have your owner manual? Gross Combined Weight Rating, and max trailer weight should be listed in a table in the Towing section. Match your equipment with the table.
Old Aug 16, 2017 | 11:44 AM
Jesse73iditurbo
I don't have the manual
Old Aug 16, 2017 | 12:44 PM
mrollings53
My '96 manual only lists a 4x4 regular cab F350, and zero diesel applications, but it should be comparable to a 460. I have a feeling that the diesel tow ratings came in the Diesel Supplement Manual.
Max GCWR for a 4x4 F350 manual 460 4.10 gear is 16000 lbs, and max trailer weight of 10400 lbs. If you want to increase that to 18500 lbs GCWR, and 12500 lbs trailer weight swap out the manual for an E4OD.
Old Aug 16, 2017 | 06:33 PM
Conanski's Avatar
Conanski
My '90 owners manual says the max GCWR for that combo is 14k.
Old Aug 17, 2017 | 03:51 PM
tjc transport's Avatar
tjc transport
i ain't rite
i know for a fact that it will handle 23,000 load machine and trailer, cause i did it with my 88 for 3 years.
Old Aug 17, 2017 | 06:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by PLC7.3
This is right from the Ford Recreational vehicle and trailer towing guide 1992-3....
The GCWR of the Fseries trucks towing a frame hitched trailer.
F series with 7.3 and automatic is:
355....12000lbs
410....17000lbs
F series with 7.3 and manual is:
355....12000lbs
410....14000lbs
The CGWR of the Fseries trucks towing a Fifth wheel trailer.
F series with 7.3 automatic is:
355....12000lbs
410....17000lbs
513....18000lbs
Fseries with 7.3 and manual is:
355....12000lbs
410....14000lbs
513....17000lbs
Old Aug 17, 2017 | 06:53 PM
Jesse73iditurbo
Originally Posted by FORDF250HDXLT
ok so that's how much it can tow. What about tongue weight?
Old Aug 17, 2017 | 07:15 PM
tjc transport
i ain't rite
most hitches are only rated for 5000 lbs max weight.
Old Aug 17, 2017 | 09:49 PM
mrollings53
I haven't seen a hitch rated for anything more 1600 lbs tongue weight.
Max tongue weight is determined by the gross axle weight rating and the gross vehicle weight rating. You shouldn't exceed either of them. Load your truck with whatever your typical load is then take it to a CAT scale. Subtract your scale weight from the gross weight on your door jamb sticker, if you get weights per axle subtract the weight of the rear axle from the gross axle weight rating on the door sticker. The lower of these two values is your max tongue weight.
Old Aug 17, 2017 | 09:51 PM
mrollings53
No, that is how much the truck and trailer can weigh. Subtract the truck scale weight to get the max trailer weight.
tarynlca
Jan 18, 2018 11:39 AM
AKHunter93
27
May 9, 2016 04:42 AM
BlueOvalLover
Jun 30, 2014 05:00 PM
sstarnes
All Things Towing
May 4, 2004 06:42 AM
Okie DRN
Jul 27, 2002 09:28 AM
