sodium
Old Aug 16, 2017 | 08:51 AM
oldbird1965's Avatar
oldbird1965
sodium
On my last oil test it shows a high level of sodium. Glycol however is negative. Should I be concerned? Where do you think I should start looking? The injector O rings were replaced about 30K ago. At home I have a extra spare oil cooler, I might put that one on when I get home late Oct.
Old Aug 16, 2017 | 10:20 AM
fordman67's Avatar
fordman67
Dont drive the ox into lake Michigan?/
honestly sodium I'm not sure where that could co.e from?!?!
Old Aug 16, 2017 | 10:21 AM
nossliw's Avatar
nossliw
You accidentally dripped sweat into your oil sample didn't you!
Old Aug 16, 2017 | 11:23 AM
madpogue's Avatar
madpogue
Great Salt Lake, more likely......
Anyway.... to the OP, have you considered asking to the UOA lab about likely sources of sodium in crankcase oil?
Old Aug 16, 2017 | 11:54 AM
oldbird1965
This is what they said:
*WEAR LEVELS APPEAR NORMAL.
*SODIUM LEVEL APPEARS HIGH. THIS MAY INDICATE A SLIGHT OR
INTERMITTENT ANTIFREEZE LEAK. GLYCOL TEST IS NEGATIVE,
HOWEVER.
*CHANGE OIL AND FILTERS (IF NOT ALREADY DONE). RESAMPLE AT
NORMAL INTERVAL
Old Aug 16, 2017 | 12:05 PM
paintubturner's Avatar
paintubturner
Where do you send your oil and how much does it cost?
paintubturner
How often to you test strip your antifreeze?
Old Aug 16, 2017 | 03:03 PM
Kingkong0192's Avatar
Kingkong0192
Possible you used the same funnel to funnel coolant into something else and trace elements of coolant washed into your motor when you used said funnel to funnel oil into your truck?
Old Aug 16, 2017 | 03:25 PM
oldbird1965
Lake Michigan 'unsalted' lol.
I was sweating but there wasn't room to put my head inbetween the five gallon bucket and oil pan. lol
I guess the source is antifreeze?
I use Sheaffer's oil and they do free oil samples. I use my test stripes every once in awhile and it tests good. I use one of those precharged filters.
Good question, I did add some antifreeze because its gradually going down but I 'think' I just poured it in. I was on the side of the road because my brake light came on and noticed the coolant level a little low. If I had a memory maybe that's a possibility.
Old Aug 17, 2017 | 07:47 AM
oldbird1965
I just want to add one more thing. Sodium last test was 11, last several tests it was 20 or below. The recent test was 115 and my coolant level is slowly going down. I have a problem that I want to figure out. If I remember right isn't it the glycol in oil that is hard on bearings? If so then I don't have an emergency on my hands, I hope.
big inch
Sep 9, 2013 02:01 PM
joeyd61
Aug 17, 2011 12:00 PM
paddlesplash
Mar 14, 2011 09:10 PM
