Offroad & 4x4
2wheel Conversion
Old Sep 7, 2003 | 07:11 PM
greyghost's Avatar
greyghost
2wheel Conversion
Anyone know if it is possible to convert an 83 Ford 3/4 ton 2 wheel drive to a 4 wheel drive???????
Old Sep 7, 2003 | 09:13 PM
wildjon300ci's Avatar
wildjon300ci
2wheel Conversion
Yep....it's bolt on. Just go out and buy yourself a 4x4 junker truck and bolt it onto yours. It's (in MOST cases) easier and usually cheaper to just buy a 4x4 truck though.
Old Sep 8, 2003 | 02:50 PM
Txquadhunter24's Avatar
Txquadhunter24
2wheel Conversion
it's just a bolt on swap for the 1/2 ton trucks. As for the F250 and 350 trucks the Frame's aren't dempled on the front for the leaf sprung fronts perches. If your not goin g to use the 4wd for offroad use. But just to have 4wd in case ya need it. you can bolt up a 1/2 ton ttb D44 then do a 8 lug hub swap. IMO it'd be easier to buy a f250 or 350 that is 4wd, Unless you wanna do alot of fab work to mount the leaf sprung front.
