99 Ford Expedition
Old Sep 7, 2003 | 07:07 PM
Maintlav's Avatar
Maintlav
Question 99 Ford Expedition
Need help with 1999 Ford Expedition
I here a problem with a 1999 ford Expedition. I have no brake lights and can not put the gear shift in to drive or move it at all.
The car starts normally. I have checked all the fuses and they all checked out ok. The owners manul say's this is a safety feature and gives instruction on checking the fuses and the bulbs which I did with no success. Can someone please help??
Old Sep 7, 2003 | 08:37 PM
PaulC's Avatar
PaulC
99 Ford Expedition
I assume that you verified that the five-amp fuse for the shift lock actuator and fifteen-amp fuse for the brake light switch are good.
If so, the shift lock actuator is acting up, probably as a consequence of a bad brake light switch. This device is mounted on the steering column. The actuator is energized (locking the shift lever) by turning the ignition key to the run position. The actuator should be de-energized at this point by pressing the brake pedal. Apparently this is not happening in your case. The trick to get the transmission in gear is to get the shift lever out of "Park" and into "Neutral" with the ignition switch in the position just before the "run" position. Once you get the trans into "Neutral", you can start the engine and shift into gear.
Just realize that you have to repeat this routine every time you want to shift out of "Park" and the brake lights will still be inoperative.
johnkirk
41
Mar 4, 2016 02:04 AM
mikie1977
Feb 23, 2014 10:12 AM
THUNDERBOLT5150
Apr 28, 2009 10:34 AM
Kev Dog
Dec 1, 2006 06:28 PM
