Oil consumption, low boost
Old Aug 18, 2017 | 02:01 PM
ExPACamper's Avatar
ExPACamper
Originally Posted by lpzd
as i understand 38R is not diy rebuild-able with bearing kit like stock journal bearing turbo.
I completely missed that part Thanks for the correction
Old Aug 18, 2017 | 07:28 PM
timmyboy76's Avatar
timmyboy76
If them 2 clamp seals integrity are compromised, then oil will make its way to the tailpipe
Old Aug 20, 2017 | 01:57 PM
abowman's Avatar
abowman
So I just did a 500 mile round trip fishing yesterday, fresh oil in the whole truck. Up pipes fixed, new clutch and never had a hint of oil burn smell at all, never used a drop of oil, (boat is white) all that is on it is black crap from the smoke but no oil at all. So I have no clue, everything seemed to be normal, boost was 36psi at wot when passing a couple cars up the pass. I'll keep driving it and see what happens, if I keep using oil I will put the stock turbo in and see what happens.
Old Aug 20, 2017 | 07:03 PM
abowman's Avatar
abowman
2 clamp seals?
Old Aug 20, 2017 | 10:55 PM
timmyboy76's Avatar
timmyboy76
There's 2 snap rings on the turbine shaft. Didn't know, you were running a different turbo...
fordland15
Jul 17, 2019 09:45 AM
Blackzombie
Feb 2, 2019 09:02 PM
mel105hunting
6.4L Power Stroke Diesel
Jul 24, 2017 03:35 PM
jeffdoerr
Nov 18, 2007 10:40 PM
Berne
Aug 31, 2004 11:57 PM
