Modular V10 (6.8l)
Towing Modifications
Old Aug 14, 2017 | 06:05 PM
Gwayne's Avatar
Gwayne
I have a 2003 F250 Super Duty 4x4 with V10. I want to buy a fifth wheel Ford says it will tow 10,000 pounds. That's not a very big trailer. Is there any modifications that can be done to tow more. It has 3.73 gears and stock engine. It has Kand N cold intake set up but that's it.
Old Aug 14, 2017 | 06:45 PM
Wolfboro's Avatar
Wolfboro
You can swap rear end to 4.3 , that will increase 5th wheel towing capacity to 13,800 Lbs (like my truck). That's all you can do in real terms . Make sure the 5th wheel you want to buy has a "hitch weight" less than 2000 Lbs. and the less the better ( since your F-250 has less gross vehicle weight rating -GVWR , compared to F-350 and there is nothing you can do about it ) . After market additions (tunes, air-bags,etc) will not increase your factory recommended towing capacity . Good luck,
Old Aug 15, 2017 | 12:08 AM
V10man's Avatar
V10man
gears, headers, free flowing exhaust, gears
Old Aug 15, 2017 | 03:45 AM
Im50fast's Avatar
Im50fast
lol I like how you mention gears twice:
like swapping from 3.73's to 4.10's and loving that. Then get headers and free flowing exhaust, and then spend another $1500 on gears again to go even lower.
Good times.
Old Aug 15, 2017 | 06:43 PM
WE3ZS's Avatar
WE3ZS
Good times.
My list would be:
Gears
Tunes
Gears
Headers
Gears
Exhaust
Gears
But I'm not suggesting to redo the gears multiple times, I'm just stressing how going with deeper gears is THE BEST option for improving the towing prowess of the V-10 platform. My V-10 EX only tows (11,000lb TT) for us these days with no daily driving and I have done all the mods I listed and without question, the deeper gears made the single biggest improvement in towing performance.
Old Aug 16, 2017 | 02:46 PM
mptjelgin's Avatar
mptjelgin
I agree that the answer is gears.
I've towed heavy with two different V-10 Superduty trucks. The first came stock with 3.73 and I paid to change it over to 4.30. That made all of the difference. When I ordered my current truck I spec'd out 4.30's to begin with.
It really makes a huge difference in the V-10 trucks.
Old Aug 18, 2017 | 10:48 AM
truckfella's Avatar
truckfella
OP: where do you live, what elevation? And what kind of terrain and speeds will you typically be towing?
The answers to those questions would help to dictate just how deep of gears you may consider.
Old Aug 20, 2017 | 07:45 PM
Bently_Coop's Avatar
Bently_Coop
I would include tire size and if OP plans to upgrade to a lift kit.
Play around with the calculator at 4lo.com to find the sweet spot.
Old Aug 21, 2017 | 06:39 PM
super 6.8's Avatar
super 6.8
I have only had 2 F250's. A 99 v10 and my current 2007 V10. Prior to buying the 99 I test drove 2 v10's back to back...a 3:73 and a 4:30. I ordered the 4:30.
My current v10 also has the 4:30. I can't imagine either truck without them.
qflyer
All Things Towing
26
Jan 17, 2015 07:10 AM
Donordad
Modular V10 (6.8l)
13
Aug 27, 2014 04:24 PM
racinghoss
Jun 17, 2009 09:43 AM
viejo loco
Sep 8, 2008 08:09 PM
Shannonm1
All Things Towing
Jun 3, 2003 07:12 PM
