sloppy steering
Old Aug 15, 2017 | 06:47 AM
Txfoster's Avatar
Txfoster
Originally Posted by troverman
My thought is this: when a truck is brand new, the rubber bushings in the panhard rod and radius arms are really tight and nice. But at 16k miles, they have probably already started to elongate and crack slightly. It doesn't bother some people, but you and your daughter are noticing it. Likely, the same thing happened to your 2016 truck.
Knowing the quality of the Ford shocks, the steering dampers are probably failing early, too. They aren't subjected to as much impact as a road shock, but you could also be feeling increased feedback through the damper if its failing.
What I found it that replacing the radius arm bushes and panhard rod bushes with "poly" bushings is the best thing to do. These don't crack and last so much longer than the rubber ones.
Most worm and roller steering boxes like what's found on these trucks have a screw or bolt that allows you to "tighten" or "loosen" the steering. This won't affect feedback, though...it just makes the steering effort more or less.
My truck has 12k miles on it, and the steering seems identical to how it was when new. I live in one of the worst pot-hole ridden frost-heaved areas of the country, and my 350 dually is one of the stiffest-riding trucks out there.
Good luck, hope the dealer can help you out.
Do have a question for you..
I've noticed in about the past 2k mile my steering wheel has a very faint rattle feeling.
You cannot hear it strictly feel when holding the wheel.
Noticibly more rattle when holding wheel left than right!
Old Aug 15, 2017 | 07:56 AM
troverman's Avatar
troverman
Do you have adaptive steering?
Old Aug 15, 2017 | 08:04 AM
Txfoster's Avatar
Txfoster
No adaptive steering
4x4
No lift or level
20" Wheels front 55psi and 60 rear
Old Aug 15, 2017 | 08:20 AM
troverman's Avatar
troverman
When you are talking about "holding" your steering left or right, are you talking about turning and holding the steering at full lock (when backing into or coming out of a tight spot)? Or are you just talking about giving some normal steering left or right to just turn a corner, etc. ?
Old Aug 15, 2017 | 08:23 AM
Txfoster's Avatar
Txfoster
Just normal let/right turning. Hardly ever do full lock.
Old Aug 15, 2017 | 08:24 AM
Txfoster's Avatar
Txfoster
Actually even when wheel is centered just is more prominent when off center.
Old Aug 15, 2017 | 08:31 AM
troverman's Avatar
troverman
I guess I'm at a loss. You're describing it as a vibration or rattle? I guess its possible some rattle from the engine / transmission is coming through the steering?
Old Aug 15, 2017 | 08:36 AM
Top_Speed1's Avatar
Top_Speed1
Originally Posted by Beeg250
I just installed a BDS/Fox dual steering stabilizer and mine is still sloppy. Do you guys have the adaptive steering? I'm starting to think the adaptive steering is the issue. Or it could be just the way these trucks are. I'm coming from a 2016 Denali also and was use to its tight steering.
Coming from a Denali also, I think this difference is mainly the IFS. The Denali was a bad *** riding truck with plush isolated steering wheel comfort (very little road bump, slop, wiggle or chatter).
[on the SD's] I can add; trucks with the snowplow pkg have the worst of this experience. Also the Fx4 package is no savior either, I like the plain-ole 4x4 package for best overall ride, and my salesman tipped me to this once I said "I want the best ride possible and I'm coming from a Denali that rode like a Cadillac!"
Old Aug 15, 2017 | 08:39 AM
Txfoster's Avatar
Txfoster
Originally Posted by Top_Speed1
Coming from a Denali also, I think this difference is entirely the IFS. The Denali was a bad *** riding truck with plush isolated steering wheel comfort (very little road bump, slop, wiggle or chatter).
I do have FX4, but for the the first 10k and for a solid axle truck, I considered it a "Cadillac" type ride.
Old Aug 15, 2017 | 09:03 AM
stufarmer's Avatar
stufarmer
I've gotta chime in on this one. I've had all new, 2011, 13' 15' 16' and now a 17' Super Duty. I still have the 16', it has about 8000 miles it now. I ordered the 17' before ever driving one. Actually, I never test drive a new vehicle before I drive it. I figure if it's good enough for you it will be good enough for me. Im kind'a regretting that now. None of my prior Super Duty's drive like this 17'. The 17's steering feels loose with 200 miles on it. There's to much play at center. Kind of a wander feeling like a worn Steering Stabilizer might feel.
Idk .. As mentioned earlier, I'm going to play with the Air Pressure a bit and see if that makes an improvement ..
Old Aug 15, 2017 | 09:47 AM
shortride's Avatar
shortride
That's usually an indication that you're driving too fast for the road conditions.
Old Aug 15, 2017 | 10:08 AM
Top_Speed1's Avatar
Top_Speed1
I'm happy with the ride, just the Denali was significantly better, but I guess ya can't have everything!
Old Aug 15, 2017 | 04:29 PM
  #28
jimzpsd's Avatar
jimzpsd
Exactly, good description. Its as though a wheel bearing is loose or the drag link at the pitman arm is loose.........definitely not "normal".
Old Aug 15, 2017 | 04:34 PM
  #29
Txfoster's Avatar
Txfoster
Exactly! even some of the items that seem possible culprit's.
Old Aug 15, 2017 | 08:56 PM
  #30
Beeg250's Avatar
Beeg250
I've also had an 08 and 12 Superduty, and ran the same Icon leveling kit on all of them, and they all had tight steering until the day I traded them. This 17 model drives like crap and only has 600 miles on it.
Have any of you guys with prior year Superdutys studied the front end components on the 17 vs older years to see if they changed something in 17? I keep blaming mine on the Adaptive Steering, but it seems like some of you without it are having the same issues I am.
