Boost leaks!!
Old Aug 10, 2017 | 05:44 PM
97-psd's Avatar
97-psd
Boost leaks!!
I have felt for awhile that I have a boost leak. I built a handy dandy leak detector last year but just around to using it today. I found a seemingly big leak from the turbo to the Y pipe. New gasket and all is good there. Found a leak at the map sensor. New clamp fixed that one. Amazingly the plenums do not seem to be leaking. I have a gauge on the leak tester and it never got above 10-15 psi. Is this normal? I expected to build about 20psi and maintain it for the test. I do have a fair leak at the CCV doghouse, which I didn't think would be abnormal. I just expected to build more during the test. I don't have the biggest air compressor, but it is a 30 gallon belt drive Speedaire. It normally supports any air needs pretty well
Old Aug 10, 2017 | 05:51 PM
madpogue's Avatar
madpogue
Isn't there a way to install the leak detector further downstream, past the CCV?
Also, something I've wondered about wrt. boost leak detection - with some four-cycle engines, there's a phase at the end of the exhaust stroke / beginning of the next intake stroke where both valves are open. I ***THINK*** if one of your cylinders is in this state, that would have an effect on how much pressure you can build. I just don't know anything about the valve/cam mechanics of the PSD, so this is speculation.
Old Aug 10, 2017 | 06:45 PM
97-psd's Avatar
97-psd
Good point.
I just had a thought, I have some carb port plugs. I bet one would fit over the the prong inside the intake. If that doesn't work I may need to get an adapter and get past the CCV and see if I can build more pressure
Old Aug 10, 2017 | 09:58 PM
knottyrope's Avatar
knottyrope
Can plug the exhaust pipe during the test if a Valve is open
Old Aug 10, 2017 | 10:01 PM
madpogue's Avatar
madpogue
^^^ +1; good idea. Or unclamp the downpipe and plug at the turbo exhaust outlet. Less volume to fill that way.
Old Aug 10, 2017 | 10:58 PM
7.3 forever's Avatar
7.3 forever
I took intake completely off put a cap on the intake and unhooked my map sensor line and put my air blower in line and had someone watch my boost guage I only pulled trigger half way and pegged my boost guage out which only goes to 30 psi
Old Aug 10, 2017 | 11:00 PM
7.3 forever
I still have a small boost leak at back corner of my intake plenum
Old Aug 11, 2017 | 07:49 AM
knottyrope's Avatar
knottyrope
time to reseal it and get better boost after
Capt.Schenk
18
Feb 9, 2017 11:13 AM
x94ray
Dec 28, 2016 08:10 PM
biggdirty7.3
42
Dec 25, 2016 05:45 PM
1994diesel
Apr 13, 2008 02:19 AM
alstieg
Nov 9, 2007 12:42 PM
