Recon cab lights
Old Aug 10, 2017 | 10:34 AM
swlakingranch's Avatar
swlakingranch
Recon cab lights
Has anyone installed the recon cab lights? Can we see some pics? I would like to hear some reviews before I buy them.
Old Aug 10, 2017 | 11:00 AM
Mfoltz's Avatar
Mfoltz
I'm also wanting to know about this. I was about to order them until I found out that their glued down and you have to reglue the new ones. I'm OK with doing that but I was worried if something leaked and wouldn't be cover because I change them with after market lights.
Old Aug 10, 2017 | 01:27 PM
bwcidaho's Avatar
bwcidaho
I have the smoked Recon white LED cab lights going on my Black Platinum 250. Waiting to install with my new tank and sending unit when they arrive.
I'll post some pics when it's done.
Old Aug 11, 2017 | 08:44 AM
Merlin053's Avatar
Merlin053
Recon clear lens with amber LED on the left, factory on the right to show the difference. Siliconed the foam on the install, no leaks yet.
Old Aug 11, 2017 | 11:12 AM
17 Oaks's Avatar
17 Oaks
REAL question is: WHERE???
So far 3 dealers have turned me down because the moon roof "causes the lights to leak".
NO, the lights leak because you did a poor job of installing them.
Cost of the install on a non '17 is $450 -$600 based upon the 3 quotes I have got and then withdrawn...
Old Aug 12, 2017 | 07:21 AM
swlakingranch
I will be doing the install myself. My truck came with cab lights from the factory, I just don't care for the yellow. I would prefer smoked or clear of the recon lights. If you wanted to install them yourself there is a seller on eBay who sells the OEM lights, wiring, and even comes with a template.
Old Aug 12, 2017 | 07:58 AM
17 Oaks's Avatar
17 Oaks
I am thinking the way to go on a fresh install is non-oem lights. The reason for this is thw 'square hole' that Ford punches in the roof. It is my guess that Ford does this to insure alignment and that the Alum does not wallow as much.
Alum is soft and you might note when its attached to they generally use pop rivets. They do that to keep tension on the to work pieces and to provide more contact than the threads of the screws. The other mitigation is to have a fairly thick gasket that is adhesive on both sides so it attaches to the light and the cab.
Old Aug 12, 2017 | 11:49 AM
Tearitin's Avatar
Tearitin
I had a set of Recon lights installed in DFW. After market looks great, they don't leak. I just found out where the dealer was going to send the truck and took it myself, save about $300 from their cost. Out the door cost was about $400 installed. I took about 2 hours for them.
Old Aug 12, 2017 | 12:15 PM
17 Oaks's Avatar
17 Oaks
Do you have a moon roof, if so, NAME of the dealer that did the install...I will drive to Dallas to get it done...
Old Aug 12, 2017 | 03:21 PM
swlakingranch
Could you post some close up pics?
Thanks
Old Aug 12, 2017 | 05:52 PM
Tearitin's Avatar
Tearitin
Yes it does have a moonroof. Truck Toys on 35E in Farmers Branch is where it was done.
Old Aug 12, 2017 | 07:43 PM
willynilly's Avatar
willynilly
if you have to start from scratch and cut the holes i would check into the lights from a new ram. im not really a fan of cab lights but theyre clear , fairly low profile and the best looking out there imo
Old Aug 12, 2017 | 08:28 PM
17 Oaks's Avatar
17 Oaks
Got it, lived in Farmers Branch for several years....
Sent them an e mail to lock in a time to have it down in Sept when I am there on business...
Thanks
Old Aug 12, 2017 | 11:46 PM
bscooter99's Avatar
bscooter99
These look to me like the old taller "bubble" style lights. Not the newest recon puts out. Can you confirm?
Old Aug 13, 2017 | 01:11 PM
swlakingranch
I think you are right, that's why I asked for a closer pic.
