05 smoking
Old Aug 9, 2017 | 03:32 PM
Ih1466's Avatar
Ih1466
05 smoking
05 with 195000 miles Started smoking on me the other day taking off at a red light I would say it is white smoke smells like burnt oil has egr delete new injectors from ford about 2000 miles ago new oil cooler dummy plugs ipr valve and cleaned turbo about 300 miles ago I'm getting no codes just pulled down pipe off and it is bone dry put fuel gauge on it shows 62 psi at wot I'm stumped at this point not loosing coolant checked the oil level and it is on the full but I will keep an eye on it any ideas
Old Aug 9, 2017 | 04:16 PM
FiznUKa's Avatar
FiznUKa
Sounds like an injector went south. Does the smell in the exhaust burn your nose. May need to do a bubble test.
Old Aug 9, 2017 | 07:47 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
This happened on a 2006 F350 we worked on.
He brought it in thinking it had bad compression, after pulling codes #7 showed as bad. After replacing the offending injector, up pipes, and rebuilding the turbo, he was back on the road without issue.
Check for codes and see what comes up
Old Aug 9, 2017 | 08:40 PM
Ih1466's Avatar
Ih1466
The only codes I have are egr related because of the delete. I have a friends matco scanner and was watching injectors on live feed and none look any worse then the other
Old Aug 9, 2017 | 08:43 PM
Ih1466's Avatar
Ih1466
I am thinking the same. I will smell it in the morning I drove about 20 miles tonight and it only smokes at one stop sign
Old Aug 10, 2017 | 07:30 AM
Ih1466's Avatar
Ih1466
Kinda hard to see but that was power balance test this morning when it was smoking
Old Aug 10, 2017 | 07:33 AM
WatsonR's Avatar
WatsonR
That uncompensated?
Old Aug 10, 2017 | 07:40 AM
Ih1466's Avatar
Ih1466
No is ids the only scanner that will do that?
Old Aug 10, 2017 | 03:56 PM
WatsonR's Avatar
WatsonR
I believe so. You really need an uncompensated graph to see how they are performing.
Any codes?
Old Aug 10, 2017 | 05:11 PM
Ih1466's Avatar
Ih1466
No codes called one dealership $249 to plug it in. Called another dealership $80 to plug it in. I'm taking it in next Friday will keep everyone posted
Old Aug 10, 2017 | 07:56 PM
WatsonR's Avatar
WatsonR
Maybe a member near you has IDS? Post in the state chapter forum and ask.
Old Aug 11, 2017 | 01:57 AM
Yahiko's Avatar
Yahiko
Still #8 looked a but busy.
The only real telling test is an uncompensated test.
$80 for an IDS plug in and a look see at the dealer is not bad at all.
Old Aug 25, 2017 | 05:14 AM
Ih1466's Avatar
Ih1466
a little update took the truck to the ford dealer last Friday told them the story and he said it couldn't be an injector he has never seen one do what mine was doing. So went home that night and changed the oil looked up at drivers side exhaust manifold and found that #8 was dripping fuel out of it. call my dealer to have them warranty the injector put it in Wednesday night and haven't had a problem yet. thanks for all the help guys.
Old Aug 25, 2017 | 06:57 AM
navistarnut's Avatar
navistarnut
Thanks for posting the fix!
Good catch.
Was this injector a Ford reman?
Old Aug 25, 2017 | 08:36 AM
Ih1466's Avatar
Ih1466
yes it was i put all 8 in around April
