Balancing Daily vs Recreational Needs in a Truck
The one really interesting thing I learned so far is that my boss's 2016 F150 with the tow package and 3.55 gears is "rated" to tow only 1,000# less than a F250 6.2L gas with 3.73 gears. While other factors do come into play (payload, stability, ect), this is why I have a really hard time buying a 6.2L engine at these prices, because when not towing daily, the EcoBoost gets much better fuel economy on day to day usage. But that is another topic.
I'm not sure you guys are helping or hurting! This has been my feeling during this whole process so I guess you're just confirming my intuitions. I think the biggest hurdle to clear mentally was confirming to myself that I am prepared to get the diesel and the pros and cons that are attached to it.
Yup, that's where the original search started but lack of dealer inventory shifted the search elsewhere. I agree the 4.30 would be a suitable alternative. There is always the option to custom order the truck but first, I was waiting to see if any EOY deals could be found. If none are found, then maybe a custom ordered 2018 will be the final solution.
Received 6,693 Likes
on
I've been very pleased with my 2017 F-250 Super Duty Platinum FX4 with a 6.7 diesel and 3.55:1 gears...If I'm understanding the towing capacity information correctly for my truck, it will tow 13,600 lbs. 2017 RV &Trailer Towing Guide
Driving an F-150 compared to a Super Duty is like driving a sports car compared to driving a tractor. F-150 is not as good as stable a tow platform nor are certain parts of the truck as heavily made as the Super Duty...but the 150 gives you much nicer steering, much better handling, a much better ride quality, better brakes, and a much faster truck. Myself, I would consider a your towing and hauling needs, as well as preference.
1. If you like to be thought of as a tough guy with big trucks, then go for the Super Duty.
2. If you plan to frequently tow near the limit of a 150, then it would probably be best in the long run to move to a Super Duty.
Diesel vs gas? The 6.2L is a very good engine and has different design parameters than, say, an EcoBoost engine in the 150. Those are very powerful motors but the 6.2L is more an engine that is detuned, designed to idle for hours on end, designed to run for several hundred thousand miles. Not saying an EcoBoost won't, but the 6.2L is more understressed in the Super Duty application than an EcoBoost would be.
The diesel obviously has more power. It really isn't much quicker in terms of get up and go, 0-60 times are very close. But, if you strap a heavy trailer to the back of the truck...the diesel engine moves the truck pretty much the same as it always does and the gas engine will start to work harder and struggle and slow down. The diesel engine will achieve better fuel economy, but don't buy it for that reason.
The downsides to the diesel are much more expensive oil changes, harder to work on, and the possibility of some very expensive repairs.
on
I think you're actually understating your truck's towing capacity. It appears your truck can tow between 14,100lbs up to 15,000lbs conventionally. Whether you are at 14.1 or 15k lbs depends upon what GVWR your F-250 has, since multiple can be chosen. Likewise, gooseneck or 5th wheel towing will be 14,100, 14,300, or 14,700...again, based upon your truck's GVWR.
I actually think Ford makes the towing capacity pretty easy based upon that towing guide link. You just need to know your truck's wheelbase, engine type, 4x4 or 4x2, GVWR, and axle ratio. All of that information is published on the truck except the axle ratio...but plugging the VIN number into ETIS or generating a window sticker will supply the axle ratio.
#28
(Or I do what my wife says and sell all the tractors)
#29
I'd just buy the diesel. I tow that kind of weight with conventional bumper pull towing - pintle hook or 21k ball hitches - just modern tractors and such.
These modern 6.7L diesels have no problems in the winter - they start nearly instantly (maybe 2-3 seconds glow plug wait) and run perfectly smoothly. It will take a little longer for the coolant to warm up; the supplemental cabin heater works fairly well on these trucks.
#30
