AOD STARTER ISSUE
Old Jun 9, 2018 | 07:44 AM
FuzzFace2's Avatar
FuzzFace2
As noted by Wagonboy and Matthewq4b,, 1992 -1993 would require changing out the extension tail shaft housing to accommodate the speed odometer cable used on the 91 and older vans..
It's not only the housing but the output shaft if it has the drive gear on it or even if one can be installed if it does not.
I know on other make / model tranys it can be an issue, the housing will swap but the output shaft was not machined for the drive gear.
Just something to look into before jumping.
Dave ----
Old Jun 9, 2018 | 07:45 AM
Franklin2's Avatar
Franklin2
I believe you might need to call Jasper again. They learned some things over the years rebuilding these things, and most tranny rebuilders incorporate any little improvement mods in the older trannies to make them last longer. You may find if you talk to Jasper, that the older trans you will be getting is already modified, and after all they do warranty the trans if you use it normally as intended.
F125Lariat
Aug 3, 2017 09:19 AM
mikeytheeye
Nov 3, 2016 01:20 PM
EWHOLTZCLAW
1978 - 1996 Big Bronco
Jul 25, 2011 09:56 AM
razzouli
Jul 7, 2004 07:30 PM
