'83 F150 starter problem
Old Aug 14, 2001 | 12:44 AM
razzouli's Avatar
razzouli
I have an '83 F150, I6, AOD. When first put a new starter in it (I've been through three) it turns the motor fine but after a few starts it begins to grind really bad. Eventually, the starter just spins freely. If I loosen the bolts slightly and use a hammer to tap it up closer to the flexplate and tighten the bolts it usually gives me a few starts before it slips again. The flexplate is in pretty good condition and I have already tried a shim. I can't figure out why it won't stay aligned. It continues to baffle everyone I've talked to. Thanks in advance for any help.
Old Aug 14, 2001 | 10:22 PM
jakegypsum's Avatar
jakegypsum
I hate to sound a little on the down side when it comes to your truck but I think that the only thing you can do is replace all of the components involved. The flexplate may be worn and can cause premature ware on the starter. New starter after new starter. A shim may be what is originally needed to keep the wear from happening. Check the plate. You may have to replace it along with the the starter again. Plus, don't forget about the shim. Good luck. Jake.
Jakegypsum // Ford fleet, soup to nuts.
Old Aug 14, 2001 | 11:16 PM
restorit's Avatar
restorit
Are you sure it's not a starter problem (not involving the flexplate)? I'm not at all sure that your loosening the bolts and tapping the starter with a hammer is doing anything more than freeing a momentarily sticking bendix. That "spinning freely" sounds like the bendix (section which springs forward and engages the flywheel ring gear) is spinning, but is not traveling the full length forward to properly engage. Tapping the starter with a hammer will usually free it, but if there is excessive wear or poor tolerances it will malfunction again.
As hard as it may be to believe that a third starter could be the culprit, it is likely, especially if you've been buying them from a discount parts store, or any other, for that matter. Often, when you get a remanufactured or rebuilt, it's already seen use on a lot of trucks, and there's nothing to say that it had a quality rebuild or reman. job performed. You may consider trying another premium remanufactured (all new internals) unit, possibly from Ford. I've had four "rebuilds" to go in one year.
Old Aug 14, 2001 | 11:19 PM
jakegypsum's Avatar
jakegypsum
Old Aug 15, 2001 | 12:38 AM
Guy's Avatar
Guy
Old Jul 7, 2004 | 01:30 PM
John Luther's Avatar
John Luther
razz, I had the same problem...turns out someone had used a floor jack and jacked the tranny up by the bottom of the bell housing, thus throwing the "bell" out of round. Now the starter bolts are not true, making the starter not line up correctly. Now I am not talking about and inch or two, just maybe a 1/32 or 1/16" off center is enough to cause the demon. I have replaced all in question with the exception of the trans, that is next...
Old Jul 7, 2004 | 02:52 PM
91f250460's Avatar
91f250460
Is it the original tranny in the truck. I had a 77 f150 that the previous owner had installed a bone yard tranny in when the first one went out. To shorten the story I took it to a reputable shop that "customized" the starter and tranny to fit up properly. I don't know what trans was original, but the boneyard trans was an fmx.
T. Roberts
UFD Local 1147
Old Jul 7, 2004 | 07:30 PM
John Luther
yeah, mine is original...I reckon I need to start looking for a new tranny.
slynch
2004 - 2008 F150
20
Sep 17, 2020 05:58 AM
Hulltech41
15
Oct 16, 2019 09:14 PM
alexjp91
54
Jan 9, 2008 10:30 PM
lacroix
15
Aug 7, 2005 08:23 AM
singer77355
Mar 17, 2004 12:11 PM
