Floor Cover Question
Old Aug 7, 2017 | 12:37 PM
Crop Duster's Avatar
Crop Duster
I know this has probably been asked before, but have any of you tried the Polyvinyl floor cover that LMC sells? The rubber mat I have is in decent shape but it was a replacement and doesn't go to the back of the cab. I really would like to cover the entire floor. LMC claims theirs was molded to fit the entire floor, but I don't trust them.
Old Aug 7, 2017 | 01:04 PM
dank4120's Avatar
dank4120
I was happy with mine, it fit well, front to back, side to side.
https://www.ford-trucks.com/forums/showpost.php?p=15992091&postcount=121
121
Old Aug 7, 2017 | 01:40 PM
Crop Duster
Thanks for the reply and the link. That's just what I'm looking for. Now to order one and be PO' for two days because of their ridiculous shipping charges.
Old Aug 7, 2017 | 01:55 PM
dank4120's Avatar
dank4120
No problem. If you scan my build a bit farther down, you'll see the install. I wasn't sure if you have a 4 speed? The mat puffs up a bit here, over the cover. I think it's the extra jute, but I didn't use any glue. Anyways, I was happy, just wish I could have found and original one in green/black.
Old Aug 7, 2017 | 03:27 PM
ihcc104's Avatar
ihcc104
I got the Vinyl floor from Macs, but I believe it is the same LMC sells, (I think it was cheaper at Macs though)
It fit very well, with enough extra to trim off. There were a few spots (under the seat) where there wasnt any grain like the mold was getting worn out. But It works and looks good. I did not use any glue and cut mine so it was tight, between the seat and the gas pedal mount I dont see it moving anywhere
greenf150flareside
Apr 5, 2016 09:43 PM
jp1096
Jan 4, 2014 09:37 PM
Trigger1911
Nov 5, 2012 09:35 PM
Dunk
2004 - 2008 F150
15
Aug 31, 2004 09:49 AM
75Player
Aftermarket Products
Jun 14, 2004 08:48 PM
