Hey guys. I have a dually that breaks something on the rear axle every time I hook to a sled. The last break it sheared the axle bolts at hub AND broke the splines off the axle. Does anyone make chromoly shafts? I really want to keep the sterling but I need more strength
Honestly I do not know what they offer upgrade wise but if you half to go to a upgraded rear axle get a 05-06 up dually rear axle Ud half to run different rear wheels but I believe you'd be surprised in the shear size difference plus your speedometer will still work by installing ur current rearend speed sensor
Yeah I been doing some searching since that last post. Single wheel trucks run the sterling and duallys have the 80. Getting the hubs drilled to 8 on 6.5 should be easy enough. I have found a dodge 80 but may be a cab and chassis truck. I'm gonna check it tomorrow.
Get rid of the sterling, its a great axle but not for shock loading and pulling. I just went through this on a friends truck we built. Same thing, however he was already running SD axles, and kept shearing the bolts off the axle flange. I ended up welding the entire thing solid, and that just led to a broken shaft. It currently has a 80 out of a 550... no issues so far.
