10.25 pushed to the max. What's next?
08-09-2017, 09:01 AM
Quote:
Originally Posted by
humphrey169
It's a stinking cummins
Well I don't care I have one in a 96 too, what are you running?
08-09-2017, 10:38 AM
Gotcha. People seem to frown on cummins trucks on this forum. Thought you was thinking it's a stroke. 5x18 injectors. 67 over a 75 compound turbos
08-09-2017, 10:54 AM
08-09-2017, 05:05 PM
Wow! Humphrey that is a heck of a build. I really like it. Probably have a lot less into it than we do just trying to run the 7.3 at 400 to 450hp.....
And good work!
08-10-2017, 09:37 AM
We like Cummins, just not the POS thin metal, POS interior, ugly designed Dodge truck it comes in! Nice picture, BEAST!
08-10-2017, 07:30 PM
I bent the pinion on that sterling 2 pulls ago. Must have bent it when the traction bars bent and let the axle roll enough to break the 1350 yoke. I put a 1410 forged yoke on it and changed the driveshaft at the same time. I figured the driveshaft was out of balance but it jumps around when it spins with no shafts in it. Junked it good I guess
08-10-2017, 07:32 PM
Also the 80 had a bad hub with broken studs in it. I ended up drilling new holes in it. I could run 16 shcs in it if I need to
08-10-2017, 07:54 PM
That is one sweet build. Nice work. Once it is all sorted out it will be one tough truck
08-10-2017, 07:57 PM
Thanks man. I'm starting to worry about the stock 80 shafts. I mean they are no bigger than the sterling shafts.
08-10-2017, 08:04 PM
humphrey169
Nothing Moser can't build for you I'm sure..
08-10-2017, 08:25 PM
I figure I'll get a set before these break
08-10-2017, 08:36 PM
I've heard some quality problems with Moser but don't really know. I was thinking yukon because a shop local has them in stock
08-28-2017, 07:51 PM
I got the 80 in. The sterling ended up having a bent pinion shaft and broken teeth on the ring gear
08-28-2017, 07:54 PM
I cut the spindles off the 80 and welded the bearing surfaces then turned them on the lathe. While they were off I bored them for the 37 spline shafts. 1.630"
08-28-2017, 07:59 PM
Welded the tubes to the center section and used an 1 5/8 alignment bar for the spindles
