Fuel Pump Strainer
Old Aug 6, 2017 | 08:42 AM
Timehunter's Avatar
Timehunter
Fuel Pump Strainer
Was looking at Rock auto wholesaler closeout add and I saw:
DELPHI FS0004 {#25055458, E5DZ9A011A} Strainer
17 or 19 Gallon Midship Fuel Tank
I have never seen or heard of it. Does anyone know anything about it.
Is it something just for injected engines.
What caused me concern is the description... midship fuel tank, like it might be in the fuel lines along the frame or somewhere.
Just one of those things that make you wonder?????
Old Aug 6, 2017 | 08:53 AM
ctubutis's Avatar
ctubutis
Need to know the exact engine and year; 1985.5 and 1986 used different fuel system filters & whatnot than the others, Bill Vose (85lebaront2) knows about this stuff.
It sounds like the filter/strainer that foes on the end of the fuel pick-up tube in the tank but I haven't looked up Basic 9A011 (E5DZ-9A011-A you posted above) to learn more, this info is probably on Gary's garagemahal site someplace.
Old Aug 6, 2017 | 10:42 AM
CountryBumkin's Avatar
CountryBumkin
Yeah, at the end of the fuel pickup tube is a "strainer". That is what I believe you are looking at.
Old Aug 6, 2017 | 12:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
17 or 19 Gallon Midship Fuel Tank.
It makes me wonder why Rock Auto goofed by listing this for a truck w/a 17 or 19 gallon mid-ship fuel tank, when you consider that...
E5DZ-9A011-A .. Fuel Tank Sending Unit Plastic Meshed Filter Screen. Slips onto the end of the pickup tube.
Applications: 1984/86 LTD/MARQUIS (Fox body mid-size).
Your truck has one of these filters, but it ain't this one! Mid-ship or aft axle tank makes no difference.
What year is your truck, what size is the engine, does it have a mechanical or electric fuel pump?
Old Aug 6, 2017 | 12:26 PM
Franklin2's Avatar
Franklin2
Some people call it the pickup "sock"
Old Aug 6, 2017 | 02:01 PM
Timehunter's Avatar
Timehunter
Mine is an 85 XLT Lariat Long bed, extended cab, carb'ed 302, AOD, also put a stock 3:55 limited slip rear end in.
Also has the front and fear tanks.
Was set up foe California high altitude. Now has DS2.
Stock most everything else...
Have had it and been in constant use for over 27 years.
Don't remember how many times the speedo has rolled over....
Think it has a couple thou miles on it .......
Old Aug 6, 2017 | 02:02 PM
Timehunter's Avatar
Timehunter
Forgot to add F150
Old Aug 6, 2017 | 02:12 PM
NumberDummy
Forgot to add F150
D1AZ-9A011-A .. Fuel Tank Sending Unit Plastic Meshed Filter Screen - 3/8" I.D. / Use with mechanical fuel pump / Available from Ford & auto parts stores.
1971/79 F100/350, Bronco & Econoline & Passenger Cars except Maverick/Comet/Pinto/Bobcat.
1980/86 LTD/Crown Victoria/Grand Marquis/Town Car without CFI or EFI & F100/350, Bronco & Econoline without EFI
eric8
Feb 1, 2019 08:51 AM
dmout53
Mar 20, 2018 01:13 PM
sloppyslim16
19
May 15, 2015 05:46 PM
mrlinder151
Jul 22, 2012 10:06 AM
pgrojean
Oct 11, 2011 08:39 AM
