E4OD Fitment Expert Advice Needed?
Old 08-06-2017, 04:28 AM
kxdan01's Avatar
kxdan01
kxdan01 is offline
Hey guys,
I realize the E4OD was used in F150/250/350, Full Size Bronco, etc. I have a good one currently in a 90' F150 5.8/E4OD w/ Great Working Transfer Case.
I know the bolt pattern fits 4.9/300 6, 5.0/302, & 5.8/351, I need to know what models/years it'll interchange with please.
Will it fit newer E4OD stuff like my friends 97 F250 5.8/E4OD, or any older newer models? Do they differ much internally from Year to Year?
Thanks again and any help is greatly appreciated!
Old 08-06-2017, 09:02 AM
Conanski's Avatar
Conanski
Conanski is offline
Yeah there are some internal mechanical and solenoid pack differences but that can be addressed in some cases. I'm not an E4OD expert but there are some here and hopefully they will chime in with more info.
Old 08-06-2017, 04:56 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Originally Posted by kxdan01
Hey guys,
In 95' or so they changed the solenoid pack wiring if I'm not mistaken, so you'd have to use the solenoid pack out of the 97 if it's still good.
They also moved diodes from the transmission solenoid pack to the ECM I think? That would be another hurdle unless once again you re-use the 97 solenoid pack.
Also, what sort of use will that truck see? Heavy towing? If so I wouldn't put one from a 1990 in my truck without major internal upgrades. Center support bushing, newer punp, sprag, planetary gears, etc.
I have a ATSG E4OD manual, PM me about it if you like.
10strokin
21
10-27-2015 11:18 AM
eric88gt
12-30-2003 03:50 PM
Quick Reply: E4OD Fitment Expert Advice Needed?
