1978 - 1996 Big Bronco
the right ZF5?
Old Aug 5, 2017 | 11:37 AM
killerfrogs's Avatar
killerfrogs
the right ZF5?
I am putting a ZF5 Trans in my 89 Bronco with a 302. I'm looking for a ZF5 from a 88-91 f250 or f350 with a 351 or 300. Anyone know if having a 4x4 is necessary. A local junk yard has one I think might work. It is model s 5-42 ZF Parts List No 1307 050 051 Trans serial number #8195632. It is not from a 4x4, what is the difference in the trans regarding 4x4 or not?
Old Aug 5, 2017 | 08:29 PM
Conanski's Avatar
Conanski
The cases are different, the 4wd trans is designed to have a transfer case bolted to the back of it while the 2wd version is not and cannot be converted so you can't use a 4wd trans in a 2wd truck or vise versa.
Old Aug 7, 2017 | 11:45 AM
killerfrogs
Thank you, the search continues!
Old Aug 15, 2017 | 11:00 AM
dclack's Avatar
dclack
BUT!!! In a full size Bronco, you may have room to run the 2wd ZF with a divorced NP205 tcase. Of course this is a much bigger project and will require custom driveshafts.
Old Sep 13, 2017 | 03:08 PM
nonger's Avatar
nonger
I'm looking for ZF too. This chart helped me identify which part numbers would work:
Lambo333
17
May 28, 2019 10:07 AM
wheelieking
Aug 18, 2013 07:47 PM
ford5.8
18
Sep 16, 2012 12:40 PM
hwknsdrag
Feb 27, 2011 09:20 AM
dom tah4089
Nov 14, 2002 07:37 PM
