zf trans help
Old Feb 26, 2011 | 08:00 PM
hwknsdrag's Avatar
hwknsdrag
zf trans help
I have a zf trans out of a 97 f350 2wd , want to put it in my 96 f250 4wd can you bolt a tf case to the 2wd zf or do I need one from a 4wd? Thanks for the help.
Old Feb 26, 2011 | 08:03 PM
85e150's Avatar
85e150
You need one from a 4x4. I do not think converting one is easy. It may require a complete teardown, plus the parts.
Old Feb 26, 2011 | 08:04 PM
hwknsdrag's Avatar
hwknsdrag
Ok thanks , thought I might get away with just swapping tailshafts or some thing on 2wd model
Old Feb 26, 2011 | 10:56 PM
fordman1090's Avatar
fordman1090
I was in the same predicament last year. I even gathered the 4x4 tail housing and the main shaft and was ready to tear it down when i found a 4x4 zf5 to put in.
You could find a divorced t-case from an earlier truck such as a np205.
Old Feb 27, 2011 | 12:54 AM
Ignitiondelay's Avatar
Ignitiondelay
do you see a difference between the two transmissions?
Old Feb 27, 2011 | 08:19 AM
Pkupman82's Avatar
Pkupman82
You should be able to just swap out the mainshaft and tail housing and bolt it in. I have yet to see one you can't.
Old Feb 27, 2011 | 09:20 AM
Diesel_Brad's Avatar
Diesel_Brad
What he said, but the cost of a tail housing and main shaft are going to cost you the same amount if not more than a 4wd zf
