Bed Cleats
Old Aug 5, 2017 | 09:34 AM
xxxsherpa's Avatar
xxxsherpa
Bed Cleats
Do you just beat these into place or what? I don't want to break them but without some kind of force they wont go or so it seems.
Old Aug 5, 2017 | 09:40 AM
Torvvald's Avatar
Torvvald
Do you have a spray in bed liner that is causing the problem? I had to work on each one a little bit and the fit is tight, but they pretty much went right in...
Old Aug 5, 2017 | 10:02 AM
retiredandfree's Avatar
retiredandfree
I used a small thin file to get rid of the excess plastic burrs and that did the trick.
Old Aug 5, 2017 | 11:08 AM
xxxsherpa's Avatar
xxxsherpa
I have the liner but it doesn't seem to bother anything. I see that little seam on the cleat that's in between the gap, is that the part that you filed off?
Old Aug 5, 2017 | 11:16 AM
jims94vmx's Avatar
jims94vmx
They will bend a little from what i remember. Went in with my liner fine.....slid right in
Old Aug 5, 2017 | 12:03 PM
retiredandfree
I lightly filed all the groves and slots that slide into the bed mounted cleat. Their was some plastic mold forming burs at least on mine, and that worked. Key must be in cleat when mounting and maybe a little oil lube might help to slide jn place. Good luck
Old Aug 5, 2017 | 12:23 PM
xxxsherpa's Avatar
xxxsherpa
Filed the grooves and they went right in! Thanks for the help guys.
Old Aug 5, 2017 | 02:17 PM
1956Fatfenders's Avatar
1956Fatfenders
For anyone still struggling with these..I didn't realize why they went in so hard, until I figured this out:
Bend it, slide it in from the bottom, release it and lock it in place.
Old Aug 5, 2017 | 02:22 PM
jims94vmx's Avatar
jims94vmx
Thats what i said! LOL good pic.
Old Aug 5, 2017 | 02:25 PM
1956Fatfenders
That's what prompted my to take a picture.
Old Aug 19, 2017 | 11:54 AM
BLUENGRAY05FX4's Avatar
BLUENGRAY05FX4
They must have redesigned these maybe as a job 2... they are now hinged and slide in pretty easily:
Bed cleat
Old Aug 19, 2017 | 05:30 PM
brickman's Avatar
brickman
Do the cleats come with the truck?
Old Aug 19, 2017 | 05:33 PM
maps's Avatar
maps
I ordered a Lariat Ultimate and it came with it.
Old Aug 19, 2017 | 05:41 PM
brickman's Avatar
brickman
I ordered the Lariat only, as the supercab can't be ordered with the ultimate package, so not sure if it comes with the cleats
Old Aug 19, 2017 | 06:44 PM
c502cid's Avatar
c502cid
Job 2 also changed the holes in the cleats (where you could hook a tie down to) from vertical to horizontal.
