Stock upper coil spring ends
Old Aug 4, 2017 | 10:49 PM
Jon Richard's Avatar
Jon Richard
Are they square or tangential?
I have a 69 F100 Ranger. I purchased new coils from Eaton springs that have tangential upper ends. The old springs have a flatter end that, while not totally square they're different enough that I wonder what type spring end the upper spring hat is made to seat properly with.
Old Aug 5, 2017 | 01:51 AM
HIO Silver's Avatar
HIO Silver
Do you mean the spring end is a square cut and not tapered/ground to have a flattened tail?
Old Aug 5, 2017 | 01:00 PM
Jon Richard
No they both have square cut ends at the wire termination, neither one is a true square end meaning ground to a taper where the spring will sit flat.
The old springs last coil appears bent down towards the second to last coil whereas the new spring is a true tangential end.
Something tells me I'll never get that coil retaining strap to capture the new spring where it bolts to the spring hat.
Old Aug 5, 2017 | 11:49 PM
HIO Silver's Avatar
HIO Silver
Thanks for the pic.
You're gonna have to call Eaton to have them fix it.
When ya ordered, wasn't there an option on how the end was finished?
Old Aug 6, 2017 | 12:16 AM
Jon Richard
Thanks for the pic.
That's what I was afraid of.
I wasn't given an option, the sales guy just wanted year, make, and model. Kinda surprised considering they boast their springs are built from original factory spec sheets.
Motorhead351
Sep 5, 2005 11:49 AM
Seabeetough
Mar 25, 2003 02:03 PM
WC76TX
Jul 3, 2002 10:56 AM
