I'm working on swapping a 400 over to efi and saw some adapters to run a 351w intake on a 400. And was wondering if I'd have to do anything to the windser Intake where the thermostat mounts or will I be able to just bolt it on
I got a chance to call them today and they said I would have to change the way the way the coolant flows on the 400 which seems almost impossible besides swapping to windser heads or I could cut back the windser Intake and weld a plate on it so I'll probably do that. But another idea I had was to take a 400 intake and weld in some bungs for the injectors at work and make a adapter for the throttle body. But I'm kinda worried about not getting the bungs in right and having them leak
...hmmph...
You would think he could give you a reference to go to as there must be a demand for this adapter kit.
If you want to retain the OEM EFI/SEFI design, you will have to cut back the coolant crossover-
TrickFlow 351W Lower
TrickFlow 351C Lower
Valley sealing is not important as the kit includes a valley pan.
Many AM manufacturers offer a Single Plane Intake with injector bosses cast in. You just drill them out and insert bungs with epoxy. Then mount a throttle body on the carb pad. Of course you have to fabricate the rails and such (line material readily available).
IMO, the OEM approach will give better appearance and performance (EEC-IV).
There has to be someone who has done this and/or specializes in it.
Yeah, the M-blocks have an exhaust crossover in the intake manifold whereas the Windsors have a coolant crossover there (in the front & rear of the block).
To implement a Windosr intake will mean rerouting the cooling system's flow through the block & heads, pay attention to what you're doing here
If you use Price Motorsports adaptor plates to mount a 351W EFI intake on your 400, you WILL NOT need to reroute the cooling. The water passages of the Windsor intake are blocked by the spacer and even if the spacer did not block the intake water passage, there is NO corresponding water passage in the 400 head....so you essentially have a hole that goes nowhere.
There is another option, buy the Price spacers to mount a 351C intake to the 400 and then go buy the Trick Flow R-Series EFI upper and lower 351C intake.
I think the concern(s) are the appearance and the possibility of interference between the W coolant crossover and the 335 thermostat housing/radiator hose.
Well it will be a while before I will do anything with the efi since I was getting coolant in the oil. which looks like it was just a bad seal between the timing cover and block. But I went ahead and tore the motor down to check everything. And the crank had a little spot that ate up the number 3 rod bearing. So I should be able to get it together in a week or 2 and start back on the efi
Any reason your not going to a system like Fitech or a holley sniper? My Fitech runs awesome and I think it would be a lot easier going that route than trying to tune a stock ecu. Just curious about your plans.
Well I could be wrong but my thinking was about reliability and parts availability. Because I know if one of the factory ford parts go bad I can just go to the parts store or junkyard and have it fixed in a day or two. But what happens if the ecu or something like that goes bad how long would it take to get the parts to fix it?
Well the ecu yes, but the rest of the parts are all oem chevy on the fitech. So yeah, if the ecu goes your down a couple days, but I doubt you can run to a parts store and get a factory ecu, they at least would have to order one , so your still down a couple of days and a tune. With that said, these things (efi) have become insanely reliable and I doubt a ecu regardless of who makes it, is a thing that's just going to just quite. Sure injectors and sensors go bad, but I never hear about ecu's going out on a regular basis. But I get the desire to be as reliable as possible. I'm more concerned my fuel command center is going to quite, than anything on my TBI unit.
Reason: added more.
I believe Fitech is MAP, but so much simpler to install than what your article had you doing. Now you get to tell me why your way is so much better, right?
