Excursion Electrical Issues - Several Systems Down
Turn Signals (hazard lights still work)
Trailer Brakes
Rear A/C
Heated Seats
Cruise Control
Probably some other issues I'm forgetting.
I usually perform most repairs myself, but electrical is getting more and more complicated. Called my local Ford dealer to do some diagnostics and can't get an appointment for at least 2 weeks.
Pulled and inspected the fuses related to the dead systems, they looked ok, no blown fuses.
I unbolted the fuse panel, turned on the ignition, activated the non-working turn signals, and turned on the non-working rear air. Wiggled and pushed each connector on the back of the fuse panel to see if I could get either to start working. No luck. Looked around under the dash for loose connections, didn't see any, but it's pretty busy under there.
Spent a fair amount of time searching and reading about electrical issues on this site. My 2005 has a different fuse panel than the earlier ones with the GEM on the back that was prone to water damage from windshield leaks.
I'm not sure where to start. Anyone have a strategy or some techniques that could help me track down the problem? Wiring diagrams? Locations of all the grounds?
It's a 2005 Excursion Limited 6.8 4x4. Had it 11 years, 202k.
Any help or advice much appreciated.
A quick 15 minute job to pull the plastic shroud around the steering wheel to check it out. The tang holding the connector in place fails. Some creative zip tie work takes care of the issue.
Consider picking up a wiring diagram if you are going to dive in deeper
Wiring diagram on the way. Any other suggestions? Owners manual doesn't label the relays in the fuse panel. I would think rear air and heated seats might be run through a relay.
