6.2L V8 Discuss the 6.2L V8
transfer case fluid change
Old Jul 31, 2017 | 09:18 PM
rkmfordman's Avatar
rkmfordman
getting ready to change the transfer case fluid in my 2011 6.2 superduty have any yall done this yet? what did yall use the motorcraft fluid or something else any suggestions for the rear end fluid would be appreciated also thanks.
Old Aug 1, 2017 | 03:30 PM
82_F100_300Six's Avatar
82_F100_300Six
I don't know what it takes but most of the time the fight is getting a container higher than the fill hole. I've used the long cylindrical rear end oil containers with the pointed spout. I've also used the little pumps that screw into one qt containers (I have one for doing lube changes in my lower unit on my outboard motor).
Old Aug 2, 2017 | 05:51 AM
T diesel's Avatar
T diesel
Old Aug 2, 2017 | 12:42 PM
dkf's Avatar
dkf
I use Amsoil Signature ATF (Red label and cap stuff) in the transfer case. Takes approx 2 quarts. Use some teflon tape to seal the plugs. For the Sterling 10.5 rear I use Amsoil Severe Gear 75w140. Takes approx 4 quarts.
Seal the cover back up with Permatex "Right Stuff". Some silicones and sealants are no rigid enough so you get leaks, the Right Stuff is rigid enough. Amsoil make a friction modifer if you have a clutch type LS diff. I got the hand pump from Amsoil which screws right on to all their bottles, makes adding oil a lot easier and less of a mess.
Both are easy to do. Now would be a good time to add an 08' finned aluminum rear cover or other aftermarket cover if you desire.
Old Aug 3, 2017 | 03:57 PM
rkmfordman's Avatar
rkmfordman
thanks for the replys ive read a lot of good things about amsoil sounds like it would be a good choice.
Old Aug 3, 2017 | 08:32 PM
Rob89's Avatar
Rob89
I only have 15k on my truck so I haven't gotten to this yet but my suggestion would be to use whatever ford fluid is in it now and to do this each time you change tranny fluid. For me will be every 30k miles. People frequently neglect their transfer case unintentionally- they say "well I don't use 4x4 that much" (I've said it myself too...in the past) however they fail to realize that your transfer case is always turning...if your rear end is turning then your transfer case is turning too. Change them at the same time.
Old Aug 4, 2017 | 07:53 PM
rkmfordman's Avatar
rkmfordman
im gonna use the amsoil in the transfer case and rear end but I will use the motorcraft in the tranny.
LRSTony
Oct 14, 2010 07:00 PM
RocketMonkey28
Dec 8, 2009 07:04 AM
goirish1972
Nov 7, 2008 02:24 PM
JFUSION
Escape & Escape Hybrid
Mar 19, 2008 12:50 PM
fordf350lvr
Oct 16, 2003 11:21 PM
