6.2L V8 Discuss the 6.2L V8
F250
Old Jul 17, 2017 | 04:49 PM
LuxeLawn's Avatar
LuxeLawn
F250
I am looking for a F250 to carry a loaded weight of 2750lbs, and a dry weight of 750lbs. The truck will be used for as a pesticide truck, and as my initial investment I will need the truck to last me 75k miles on the same motor, trans, and rear end. I initially looked at only diesels and was leaning that direction until my local mechanic suggested I get a F250 FlexFuel. Can I please get some opinions from the experts out there. Obviously we can get a much cleaner truck going flex fuel with less mileage and much less on the expenditure. Thank you in advance for your suggestions.
Old Jul 17, 2017 | 05:27 PM
Ron94150's Avatar
Ron94150
Your mechanic was very wise in his suggestion. The 6.2 is a great, reliable motor. If your buying new, order one with 4.30 gears because of the continuous load you will be carrying. It will feel like a 3.73 that is unloaded. But 3.73's will certainly work fine. Also, pay attention to gvwr. With your cargo and passengers with a full tank of fuel, you could be pushing it with some set ups, but not even close to others. Wheel and tire size play a huge factor in this.
Old Jul 17, 2017 | 05:37 PM
WyoBull's Avatar
WyoBull
The 6.2 is a great motor and very reliable. Be sure to look at the payload ratings on the trucks you are looking at, especially an F250. To get above 2750 lbs payload in an F250 you will be looking at an XL or maybe an XLT trim level.
I had an F250 Lariat CCSB 4x4 and the payload was 2496 lbs. I stepped up to an F350 XLT to get more payload, as you can see in my signature. Just something to think about as you are looking.
Old Jul 17, 2017 | 06:26 PM
Chuck's First Ford's Avatar
Chuck's First Ford
as stated the "XL" trim can carry the most.. as long as its a 2 wheel drive..
I have the Super Cab Long Bed with slide in camper option.. ... cargo load is 3,600 pounds..
Old Jul 17, 2017 | 06:47 PM
JeepPuller's Avatar
JeepPuller
It is possible to hit 3k+ with a 250; just stay away from the 6.7
This is my 250 King Ranch w/6.2
Old Jul 17, 2017 | 10:53 PM
landscapeguy's Avatar
landscapeguy
Just get an f350, my crew cab lariat fully loaded with every option a lariat can have has a payload of just about 4k
Old Jul 18, 2017 | 09:44 AM
WyoBull's Avatar
WyoBull
My sentiments exactly after having an F250 with a payload of 2496 lbs and now having an F350 with a payload of 4226 lbs.
Old Jul 18, 2017 | 10:35 AM
LuxeLawn's Avatar
LuxeLawn
What kinda fuel economy do you get in the 250 and the 350. I know its not good, just curious
Old Jul 18, 2017 | 12:30 PM
Chuck's First Ford
empty is 14 city... 18 plus highway.. stay under 65.. or else.
Old Jul 18, 2017 | 12:37 PM
Ron94150's Avatar
Ron94150
18 is a 2wd in ideal conditions. If you are buying a 4wd, you will never see 18. 16 would be a good hwy average. You could easily dip into the 11-12 range if you drive a lot of city and idle a lot.
Old Jul 18, 2017 | 01:14 PM
Chuck's First Ford
just to put this out there..
yes 2 wheel drive.. and 152,000 miles..
Empty its 6,600 pounds.
I keep forgetting.. if using a phone.. that my signature is not displayed...
I only use a phone as a phone... so I forget.. as I also use a digital camera.. not a phone.
Old Jul 19, 2017 | 02:56 PM
Tarster's Avatar
Tarster
I'll check my load rating when I leave work today, but I drive 15 miles back and forth between towns and I get 12.5 as my normal, 4x4 with the 3.73 gear and I have a flatbed on my pickup, last time I ran across a small scale the pickup was 4400 in the front and 4000 in the rear, seemed a little high. I think the best I got was 45 miles each way highway and that was 13.5 never seen anything higher yet.
Old Jul 20, 2017 | 10:06 PM
Tarster's Avatar
Tarster
Gvrw on my pickup is 10800 and Max load with cargo and occupants is 3597
Old Jul 26, 2017 | 09:37 PM
Powerdude's Avatar
Powerdude
I carry a 3000 lbs camper on my 2016 CC SB F250 6.2 4x4 with the truck camper package. It has the upper and lower overload leafs on the rear just like an F350.
Not a single problem. Truck handles it just fine.
Fully loaded with gear and camping stuff I'm a bit over GVWR, but under tire limits on the rear.
Your weights will be no problem for an F250.
Old Jul 27, 2017 | 12:37 PM
landscapeguy
Yes absolutely it will handle it no problem, I never questioned that. And you're fine using the truck personally for fun, but once you go commercial (anything for money) you are not, they don't care if you are 200 over, you're getting a ticket. So why not just get the 350 for the very nominal price difference?
