Something Bad Broken? Was no start, low oil, now oil running out tailpipe...?
on
Test?
I'll bet a CCT would tell me which cylinder. Except it has to be at a certain running temp, right?
Or maybe it will *run* but not as accurate as when warmed up?
If it will run, one of my cylinders is really rough, probably oiling like a can, and should show right up, correct?
I thought of a backup method....
Since she starts really slow now...
1. Unplug 48 pin connector and crank motor over about 4 or 5 secs with starter to build ICP with HPOP. It should push past a failed oring
2. Pull the Glowplugs on the offending side and cover with a secured shop rag.
3. Crank for few moments until one of the rags is wet with oil. If it doesn't, plug in 48 pin and try again for a few secs at a time to spray the fuel+oil into the cylinder through the injector with the bad oring, and it should spray out the hole.
It shouldn't start because no compression without the orings, but the injectors don't know that, so they should still fire, right?
Now you know which cylinder has the oil from a BAD injector oil-oring leak.
Think it would work?
on
I appreciate the offer. It would be fun. But I don't think she'd make the trip at $23/gallon oil at maybe 5 miles per gallon, LOL.
If you were closer, I'd be lighting the grill
Pretty sure I have some help now. Not experienced, but I can work with that
on
I think we lubed them with oil, not assembly lube. I never saw an injector in person before that, all new to me.
I have a faint image of *something* with cylinder #2. I think I leaned on the upper coolant hose and something pushed into the cylinder. It was late, it was dark, and I had no clue.
Now I am thinking maybe injector cup or sealant? Maybe that was coolant?
I'll check it closely this time. If it is the cup, I'll setup for that job pronto as well. It is just as likely that I didn't see what I thought I saw, though, LOL.
I think I also have a better idea of what to look at/for with the injectors and their parts, too, to judge their overall health.
We didn't have a decent torque wrench in the 120+ inch lbs range. I had smaller and much larger. Time for a new tool! I used a ft-lb to retorque a few weeks ago.
What about the CAC cooler? Does it have a drain or something at the bottom for oil? Maybe it wasn't all burning, maybe the cooler is filled and wasn't working well, leading to higher EGTs?
That may have killed the turbo bearings that now need rebuilt?
Spitballing out loud here for input and opinions, please
on
Imagine you, me, and Mark....whoo-willl-wooo--willl (imagination scene music)
I won't speculate who we were calling for help, or who was correcting us from behind
I'm thinking before spinning a wrench, let's see what the pcm says.
Too many variables. You did injectors with trusted parts and did put a new fan on the turbo etc...
Generally my truck screws me when I try and love it. and then I'm on the bottom for my efforts.
Let's read some real-time and go from there.
Both issues would provide the same effect, so lets try to eliminate one possible.
Get some rest,
Denny
Get some rest,
Denny
Yeah, that would be fun, too!
https://youtu.be/3k0LI48iZEc
Received 3,743 Likes
on
#28
on
upper grove to middle grove is high pressure oil,
middle grove to lower grove is fuel,
lower grove to copper washer is nothing.
for oil to get to the cylinder it would have to go past the center grove o ring and the copper washer.
oil does erode the center o ring and dump oil in to the fuel, mixing with fuel and burning it.
I have replaced o rings where 5 center o rings were eroded and the truck was burning 1 gallon of oil every 100 miles and no wet oil in tail pipe.
#29
on
I'm going to checking copper washers and cups carefully, in case one of them failed and is dumping fuel + oil.
Did have some "contains 5%-20% biodiesel" fuel stations along the way. Not sure if they would affect anything?
I used Powerservice in the gray bottle each tank I was towing.
Not really sure what I'm going to find. Hopefully just a FROG stuck in her craw
#30
on
