6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Puddle
Old Jul 30, 2017 | 11:25 AM
RBsPowerstroke's Avatar
RBsPowerstroke
Oil Puddle
2008 Ford F250, Recently losing power and MPG, last night it was overheating, made it home. Woke up this morning and found an n"oil explosion" under the truck and under the hood on the left side. What could this be?
Old Jul 30, 2017 | 11:33 AM
Picton's Avatar
Picton
Have you had a chance to crawl under the truck and locate the source of the leak?
Old Jul 31, 2017 | 08:59 PM
DieselDenny's Avatar
DieselDenny
If you have that much oil, you need to do deep cleaning, refill the rig and have someone start it for a moment at a time. Wear glasses, you'll find the source. Let us know.
Did you just change your filter (oil filter) ???
Any recent maintenance??
Denny
Old Aug 3, 2017 | 07:56 AM
speakerfritz's Avatar
speakerfritz
any oil warning lights...I think its an oil drop light on the dash? did the engine sound like someone was shaking a tool box?
check the oil level first...then see if the leak is from the front of the engine....near the crank pulley.....there are 4 bolts that secure the oil pump and the bottom 2 have a track record of coming loose....if it is loose...re-torque it...then...pull you pressure relief valve and clean it.
Audacious
Sep 29, 2018 07:50 PM
Glenn54
Oct 25, 2016 07:33 PM
srteach
Nov 3, 2013 09:08 PM
CrimsnTide
Oct 14, 2010 08:02 PM
syxking
Mar 10, 2009 12:08 PM
