Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
'79 F700 Brake Problem
Old Jul 29, 2017 | 09:30 PM
wagonerkl's Avatar
wagonerkl
Truck has what I think is called a Hydrovac System. It has the strange symptoms of; push brake pedal once, truck brakes well, pump a second time it still stops but pedal seems to "push back" some, pump a third time and the brakes are GONE. Very weird.
I took it to the local tire and brake shop and they supposedly bled it and checked for vacuum leaks. When I took it for a test drive it behaved exactly as before. Anyone ever had this experience or understand the system well enough to know how it can brake well on the first pump and end up with no brakes on the third pump? Thank you.
Old Jul 29, 2017 | 10:02 PM
Tenwheeler's Avatar
Tenwheeler
Does it have a vacume gauge on the dash and what does it read? If not hook one up.
Old Jul 29, 2017 | 11:04 PM
wagonerkl's Avatar
wagonerkl
It does. Seems like it is between 15-20 inches on the gauge. It will take a little bump down when I hit the brakes but it stays fairly constant in that area when it gets warmed up. I do note that after start-up it takes a few minutes for the vacuum to build. I will pay closer attention to it next time I run her.
Old Jul 31, 2017 | 09:21 PM
Notmeofficer's Avatar
Notmeofficer
Send the booster to Capitol Clutch and brake in Sacramento CA for a rebuild... you wont be disappointed
Capitol Clutch & Brake
Old Jul 31, 2017 | 11:27 PM
wagonerkl's Avatar
wagonerkl
Thanks for the tip. I just watched a few videos of them being disassembled; seems pretty simple, so I may try my hand at it first and see if I can find an obvious failure mode. If it turns into a mess, I can always send it to them later.
Old Sep 1, 2017 | 01:50 PM
Notmeofficer
What I like is that they come back all blasted and z coated or galvanized...
but yes they are pretty simple inside
Old Sep 1, 2017 | 03:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pump the brake pedal several times, then press hard on it. If the pedal sinks to the floor, you have a leaking wheel and/or master cylinder.
Hydro-Vac is a remote mounted P/B booster, usually located on the frame rail.
Old Sep 1, 2020 | 02:57 PM
Jim Mowery's Avatar
Jim Mowery
our 74 f600 does the same thing when pedal gets hard and "pushes" i push clutch in and rev engine ,vac comes back up and i have power pedal again....i think booster has pin hole somewhere
Old Sep 1, 2020 | 03:23 PM
wagonerkl's Avatar
wagonerkl
Thanks. My post is a few years old but I appreciate the interest. I purchased a new booster assembly but haven't installed it yet. Too many projects
Old Sep 1, 2020 | 03:27 PM
85e150's Avatar
85e150
What's stopping you?
Resendiz
Oct 8, 2015 05:36 PM
JTS1975
Sep 13, 2011 09:35 PM
marks500
Oct 11, 2009 03:35 PM
jqp00002
Oct 14, 2007 08:37 PM
trike1946
May 20, 2007 03:55 PM
