China made bed sides?
Old Aug 8, 2017 | 02:57 PM
ingo's Avatar
ingo
Originally Posted by fordslut
one thing i will say that i found strange, was that there was no threads in the two top angel parts of the front panel that bolt the sides together. i guess you could slide 4 nuts down in there, but i made made two 1/4 thick bars with the threaded holes in them and welded them in. strange thing to leave out i thought.
maybe a rivetnut will work!?
Old Aug 8, 2017 | 06:27 PM
fordslut's Avatar
fordslut
i wouldn't, i think it's 5/16x fine, not sure if it's 18 or 24 tpi. and the nut-cert might not let it lay flat, plus i would worry about getting it tight enough. the sides were not drilled for these 4 holes, (2 per side) , so you can put them where you want them to a point. kurt-
shoveex
Feb 24, 2010 08:54 PM
1949f1
Oct 28, 2005 03:39 AM
TJDREAMS
Oct 30, 2004 12:53 AM
j gibbs
Mar 20, 2003 08:07 AM
airwick51
Feb 24, 2003 09:53 PM
