Batch Fire Vs Sequential Injection?
Old Oct 29, 2001 | 03:47 PM
brett_d's Avatar
brett_d
Can anyone explain the difference between the two?? I kinda know the basics of the differences but not the who thing!
Thank you!
1988 Ford F250 4x4, 5.0 liter (soon to be Roller 5.0), Mass Air Conversion, Rebuilt AOD tranny, 2.5 Dual exhaust, Headman Shortyheaders, 33" BFG's Mud Terrain, 4.11 gears.
1980 Ford F100, with 1988 5.0L Roller (carburated), T-5 five speed Borg Warner World Class Transmission, 31 spline 9" 3.73 posi , and a bunch more!! 13.78 quarter mile.
Old Oct 29, 2001 | 04:39 PM
StrangeRanger's Avatar
StrangeRanger
[font size="1" color="#FF0000"]LAST EDITED ON 29-Oct-01 AT 05:39 PM (EST)[/font][p]MFI (Multi-port Fuel Injection or batch fire) gangs the injectors into banks, one per cylinder head in the V engines and one for the front half and one for the rear half in inlines. Pulses are timed by engine RPM and air flow but are not timed to the individual cylinders other than using #1 as a starting point for each cycle. SFI (Sequential Fuel Injection, also called SEFI or simply EFI since the demise of MFI) fires only one injector at a time and that pulse is timed to the crankshaft position, so firing order of the injectors must match that of the cylinders they service.
In practical terms, there is very little advantage to SFI over MFI in "normal" use but when you begin to stretch the performance envelope SFI along with it's more flexible mass air (MAF) control system allows greater gains gains. Where SFI does win out is in producing significantly lower emissions, which was the primary reason for it's adoption.
Old Oct 30, 2001 | 02:20 PM
Eddie's Avatar
Eddie
Brett:
1. What exactly is the height of the roof of the cab with your wheel/tire setup?
2. Highway speed@RPM?
3. Wheel Width?
Eddie
Old Nov 4, 2001 | 06:49 PM
brett_d's Avatar
brett_d
Sorry But I really cant tell you.... I dont have a tachometer (Yet) and I have never measured the cab. I can tell you that I have a stock f250 5.0 (as far as suspension) and It fits the 33's perfectly. The wheels are 10" AR Baja's.
Old Nov 14, 2001 | 06:20 PM
brett_d's Avatar
brett_d
Post Batch Fire Vs Sequential Injection?
Question,
I Know that my truck was Batch fire before I did the mass air conversion. Now that the mass air is done did that change it to a sequential or is it still a batch fire.
I am trying to find out if I need to change the injector wires along with the distributer wires when I swap from the stock 5.0 to a roller 5.0..
Can anyone help me out PLEASE!!!!!!!1988 Ford F250 4x4, 5.0 liter (soon to be Roller 5.0), Mass Air Conversion, Rebuilt AOD tranny, 2.5 Dual exhaust, Headman Shortyheaders, 33" BFG's Mud Terrain, 4.11 gears.
Old Nov 14, 2001 | 08:38 PM
brown 4x4's Avatar
brown 4x4
1986F150six
Apr 12, 2015 02:35 AM
brett_d
21
Oct 9, 2014 12:50 AM
burnsbm0796
Sep 19, 2014 04:17 PM
burnsbm0796
Sep 18, 2014 01:34 AM
flipboard7431
Apr 30, 2014 07:30 PM
