On a Ford I'm in the delete camp. The 6.7 doesn't have a 9th injector down in the down pipe to clean the DPF. The way it does regens is to inject fuel into cyls 7&8 during the exhaust stroke resulting in a few bad things.
1. Raises EGTs in the turbo increasing the heat load and decreasing turbo life.
2. Results in some fuel coating the cylinder walls and ending up in the crank case reducing oil lubricity and reducing engine life.
3. Wastes fuel. My 2015 went through regens about every 400 miles when unloaded before I deleted it and used about a gallon of fuel each time. That results in about a 5% decrease overall fuel economy. I'd guess the 17 is about the same.
4. Requires the use of EGR resulting in "dirty" air coming through the intake.
All of these result in a lower overall life of the truck which is completely unnecessary. Even without the dpf these engines(assuming you don't tune them stupidly) make far less emmsions than diesels of yesteryear or even gas engines of today.
The 6.7 uses a complete bank for regen. Not 7 and 8.
I believe the newer trucks may use both banks.
Good to know. Although that makes it worse not better. Thanks for the correction. This stuff is hard to find out about. That's one of the main things that irks me about it. I own this truck. I paid for it. I should be able to do with it as I please. The idea that someone else can tell me what to do or try to keep me from doing what I want with my own property is bunk.
anytime I take any of my cars in for warranty, the first thing my dealer service writer does, is check for codes or maybe tunes, they attach a reader, and inspect underneath.
So if I can get it deleted and still get warranty work that wouldn't be a bad thing then?
i see two sides of the story here from people. I am trying to prolong the life of my engine
The reason for the two-sided story is because of performance. You really feel the raised RPMs that Ford gave the 2017s for peak torque. It was moved from 1600RPM to 1800-2000RPM. Couple that with the low boost fueling that is programmed into the export file that EVERYONE is selling, and you get a laggy truck off the line. Only custom tuning currently available is to take your PCM out, ship it to the tuner, wait on them to bench flash it, then wait for it to come back.
Can you build a casino on your property? A brothel? Can you turn your residential house into a commercial building? You drive your truck on roads that everyone pays for, so you gotta follow the rules that the majority has collectively agreed upon. You've never been able to do whatever you want with your property. There's always rules, rules, rules.
To be honest, at the heart of it I feel the same way you do. But I'm more happy that the retards rolling coal are about to get shut down.
I don't wanna roll coal or whatever I just want my engine to be healthy and stay alive. I'm keeping this truck for a long time. From what I understand the DPF or DEF fluid goes no where near the engine it's just annoying that you have to go into Regen mode or spend extra money for DEF
Its like $7 every oil change. Its not a lot of extra money. And it does nothing to the longevity of the engine. In fact, the way a Ford tech explained it to me was that their stock tunes are actually better on the DEF/DPF trucks because they don't have to care as much about diesel exhaust coming straight out of the motor anymore. The DPF will take care of the "less-clean" exhaust now coming out. Before they had to de-tune them to meet emissions. Now they don't.
I think the regen has to stress the engine. Extra fuel in the cylinder...can wash off the cylinder walls and will for sure end up in the oil. Plus, the heat on the turbo. Not as much of an issue if you run good oil, but many people get the cheapest oil they can find.
Dodge and Ford uses the exhaust stroke to introduce the fuel needed for a regen.
My 2015 has never made oil and the regen process is seamless.
An extra injector pumping fuel is another complete system. I don't know if I want any more complexity in an already complex truck.
My nephew bought a new 2014 King Ranch new. He debated about deleting it and spoke to our local dealership about the warranty. They assured him that they had no problem with the warranty if he did, but would only replace the turbo once. He still wasn't sure. By 10,000 miles he had been to the shop twice with check engine lights due to emissions, so he went ahead and deleted.
He now has 150,000 miles on the truck. It's never been back to the dealership once since deleting. He said his biggest mistake was not deleting sooner.
He loves the truck. He always runs a high horsepower tune and runs the snot out of it daily as his fuel is free at work. The boy could tear up an anvil with a rubber hammer and hasn't killed it yet.
It's a matter of choice. Personally, I'm not a gambler. I don't even spend a buck for a lottery ticket, so its not for me.
Recently joined the diesel community ... actually, my 2017 King Ranch won't be delivered until September ... so please tolerate my ignorance because my question is only somewhat related to this topic. If the goal of deleting the DPF is to eliminate regen cycles, and long distance driving gets the regen performed without issue, how short of a daily commute is considered too short and creates frequent regens? I ask because my daily commute is 9 miles one way.
Your commute is very short and regens will not complete themselves with that short of a drive. You'll have to take it for a walk once in a while so it can "do it's business".
Wife: Honey, where are you at?
You: Walking the truck dear.
The 2017's do not tell one when the regen is happening, thus you'll never be able to tell when and where its going on unless you learn to watch your instant fuel economy gauge. You can see the fuel economy drop during a regen. On my last 6.7, I had a Edge CTS2 which had a light that lit up while a regen was happening. (The Edge doesn't have this feature for the 2017s) Most of the time it lasted about 10 minutes, sometimes a little longer.
How do you know you're not making oil? Have you sent samples to Blacstone for testing. Others who have often note diesel present in the samples.
9 miles is never going to get everything warmed up enough to do a passive regen. Even an active regen (which will need to occur about every 400 miles) will take at least 15 minutes. I don't know if this is still true but on my 15 it wouldn't even start an active regen until the truck was up to temperature which takes a few miles at least.
In the winter months when its cold it can take as much as 30 minutes to bring the oil temps up to normal levels.
Seems to me that the raw fuel would lower the temperature of the Turbo, NOT raise it.
Why would it end up in the crankcase on an exhaust stroke? There's no compression on it. It's just passing through. Old wives tale.
Yeah, it does use fuel.
Say what?
I saw the run on the 6.0 and what happened with a lot of them. The VT365 wasn't a terrible engine. None of them are/were.
But the shade-trees get hold of them and think they're better engineers than the guys at Ford. Then, they push the engines up to 1,000 HP and can't figure out why they're blowing them up left and right. Everybody's got a Chip.
Leave your engine alone.
You wanna play Boy-Racer? Go get a small block Chevy. Dime-a-dozen
