Curious to know which is the best leveling kit for a 2WD?
I didn't extend my shocks at first and rode that way for about 5 years or more. Then, once Chris went the route of extending his due to a broken shock, I replaced my stock length shocks with some with longer travel and the bolts extenders in the same way that Chris did, and my ride is significantly improved!!
I didn't extend my shocks at first and rode that way for about 5 years or more. Then, once Chris went the route of extending his due to a broken shock, I replaced my stock length shocks with some with longer travel and the bolt extenders in the same way that Chris did, and my ride is significantly improved!!
I don't mind adding longer travel shocks, but I don't want to have to cut anything off the truck and then rethread it as I saw from some posts above. Don't you have to do that when you say "bolt extenders"?
Daystar makes some shocks for a leveled 2wd truck with no modification required, but when I tried a set, they were about as bad a ride as worn out factory shocks that should have been replaced 50k miles ago.
Rusty_S
13
08-08-2016 07:40 PM
F 250 6 liter
1999 to 2016 Super Duty
07-06-2011 07:14 PM
bjm58
11-26-2007 06:51 AM
