3rd Brake Light
Old Jul 23, 2017 | 08:27 PM
air1jpg's Avatar
air1jpg
3rd Brake Light
Looking for recommendations on a good replacement LED 3rd brake light that will not leak and includes bed lights.
Old Jul 23, 2017 | 09:11 PM
Vanquish Auto's Avatar
Vanquish Auto
Former Vendor
Is the current one leaking? I would suggest some butyl sealant around the lamp to create a gasket to stop the leak and upgrade to good led bulbs and keep the nicer factory look. Good luck with your end choice.
Old Jul 24, 2017 | 11:45 AM
projectSHO89's Avatar
projectSHO89
If you install an LED 3rd brake light, you usually loose your cruise control.
Old Jul 24, 2017 | 12:39 PM
alloro's Avatar
alloro
Okay you've got my attention, how is that possible? The CC deactivation and brakes lights are two different circuits and the CC deactivation switch is a separate switch from the brake switch.
Old Jul 24, 2017 | 01:05 PM
projectSHO89
The logic level of the BPP switch's signalling output is "pulled down" by the 3rd brake lamp (filament low resistance) to a logic "low" at the input to the PCM. Because the typical LED presents as an open circuit when not actively turned on, the BPP's logical input to the PCM is effectively floating and is interpreted as a logic "high" which, to the PCM, indicates the brake pedal is being pushed. Same thing happens if the bulb is burned out.
Previous discussions:
https://www.ford-trucks.com/forums/1...-heads-up.html
https://www.ford-trucks.com/forums/1...e-control.html
Old Jul 24, 2017 | 02:04 PM
Beechkid's Avatar
Beechkid
To address the leak........here is what I did on my 2006.....
Purchased a replacement gasket (for mine the design was revised), then IIRR I applied silicone sealant to the lens side of the gasket, applied a light tough of white lithium grease to the cab surface side of the gasket and assembled...not a drop since.
fordf348
Jul 29, 2014 07:08 PM
jlarsen513
Dec 31, 2011 08:02 PM
SBastow
May 9, 2009 05:50 AM
Tango
Jan 7, 2007 05:04 PM
